South West Region South West regional discussion board.
Looking for an LT1
Old Jun 26, 2010 | 05:21 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Looking for an LT1
As the title speaks, thinking about tinkering with one to see if I like it or not. Running or not it's getting rebuilt anyway. So anybody got one they want to get rid of?
Old Jun 27, 2010 | 12:06 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
Re: Looking for an LT1
My brother has one in his 95 formula he is parting out 750 with wiring and accessories.
Old Jun 27, 2010 | 04:22 PM
how many miles on it?
Old Jun 27, 2010 | 05:04 PM
Engine: 5.8
around 135,000
Old Jun 27, 2010 | 05:26 PM
any pics? and is your LT1 up and running? how would you rate the change from the L03 to the Lt1?
Old Jun 27, 2010 | 06:22 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Night and day
Old Jun 27, 2010 | 06:28 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Whoa, robertfrank -- Kingman, AZ! I had a great time there back in 97 taking apart some L-1011's when I worked for TWA... really enjoyed visiting Loughlin as well...
Old Jun 27, 2010 | 07:36 PM
Engine: 5.8
I can get pics but it looks like any lt1 all stock accept for the 700r4 throttle bracket and a cold air. It is running and can send a vid or you can drive it. It also has a t-56 f/s.
the swap was pretty easy and if you have a stock lo3 it is a big difference I built mine so it hade somewhere in the 425HP range that is a BIG jump in power well worth it. check out my cardomain to see what it can look like in a thirdgen an the lt1 bord has all the stuff you will need.
Old Jun 28, 2010 | 02:08 AM
Well my L03 is FAR from stock. As it stands it's a LOW 14 second car. Which by todays standards is nothing but I still have the stock heads and cam. If I were to swap to an LT1 and I don't end up in the 12's I'd be pissed. lol
Old Jun 28, 2010 | 04:10 PM
Car: 1994 Trans Am
To get to 12's with an LT1, cold air intake, long tubes, stall, tune, and drag radials. 1.7 rockers would be icing on the cake.
Traded my 96 WS6 for my gta. Fun car that LT1 was.
Old Jun 28, 2010 | 04:58 PM
The reason I'm thinking about going the LT1 route is the whole ease of installation. I can still use my stock trans and edge 3200 stall if I get a throttle body from a 93 for my kick down cable. I can still use my 2055's if I can get past the D port head issue. AND.... I already have a ZZ4 cam that I can use with it. My car only weighs 2860 without me in it alittle over 3k with my 195lb self planted in the driver seat and I still have the stock iron heads on it. So again, 12's with the LT1 SHOULD be within easy reach.
Old Jun 28, 2010 | 06:33 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
my buddy dave has one brand new. eagle crank,rods n pistons.
little bit of head work (bigger valves,etc)
I'll see if I can get him to chime in here. (were in FL.)
decided to just do heads and procharger on an l98 so the lt1 is just sitting on a stand.
Old Jun 28, 2010 | 07:32 PM
David350Formula's Avatar
Car: 89 Firebird
Engine: 350 L98
Transmission: 700 R4 W/3k stall
Axle/Gears: 10 bolt 3.23 :(
I sent you a pm about my lt1 and never got a responce . Its fresh zero miles on bottom end and with a le or ai port and cam package will put you in the 11's!!!
Old Jun 28, 2010 | 09:16 PM
Sorry about the no response, I was kind of hoping to find something closer, shipping charges are a beast,lol. North Port? I'm originally from Tampa. I still have family in Sefner and Clearwater. But if the prices are right I might consider.
One more quick question. How well do you guys think the LT1 would run with the ZZ4 cam and the 3200 stall combo? Remember I have 3.42 gears.
Old Jun 29, 2010 | 12:41 PM
Car: 1994 Trans Am
3.42s and 3200-3500 is a good stall range and that cam should be fine.
Old Jul 4, 2010 | 12:48 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
dude you're ditching the lo3??? you're the TBI guy! lol finally coming to the dark side?
Old Jul 4, 2010 | 03:19 AM
No, I'll never leave the TBI world. I'm actually on the hunt for another TBI car to use as a driver. I figure I have a whole garage full of TBI stuff to use I shouldn't let it go to waste. I just want to take it up another level once I'm completely done with the 305.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
