A Little Help please....
Car: '84 Trans am ‘86 Iroc
Engine: 305 auto, 305 auto,
Transmission: Automatic
Know this should be in the tech section, but prefer to deal with the local crowd!
I have a '89 305 TPI auto unit, in my '84 Mecham with a complete swap no mods. My problem is that recently the car runs great until it gets hot (not overheating), or if I turn it off then start back up. Seems as though # 5 and #7 cylinders are not firing after getting hot, after it cools it runs fine again. No SES lights either, just not running good. Any ideas? Anybody run into this problem? Thanks for any help.
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: A Little Help please....
Check the ohm readings on the injectors when the car is hot. Sounds like maybe a couple of bad injectors. Did you reuse the originals when you did the swap?
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I was going to guess injectors too. You can also rent a set of 'noid lights to see if each injector connector is firing.
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Injectors do not tend to get or cause alot of heat... I would be looking at coil or cat
Car: 88 IROC
Car: 85 87 87 91 92
Then why dont you bring it by the shop... We do diagnostics for 40 bucks.....
Automotion its just north of Bell on 19th ave. the address is 17219 N 19th ave its right next to the car wash across from the sonic
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
POSSIBLE IGN MODULE FAIL WHEN HOT. I HAD ONE DO THAT LAST YEAR. CHECK CONNECTION INTEGRITY ON SUSPECT INJECTORS PLUGS. AND ALL CPU GROUNDS AND SENSOR PLUGS CONNECTIONS AS WELL. MAF / IAC / MAF RELAYS / BURN - OFF / FUEL PUMP / MAF WIRE IS CLEAN
I did use the original injectors, at the time the system was running perfect. Thanks for the suggestions. I will try some of those ideas and get back. Thanks again!
ALWAYS GO FOR THE SIMPLE FAST STUFF FIRST SO YOU DONT WASTE YOUR TIME . LIKE LOW CHARGING SYSTEM VOLTAGE / BAD GROUNDS. IVE HAD THOSE TWO BITE ME IN THE **** MORE THAN ONCE.
Xenodrgn
Aug 2, 2002 07:18 AM
