South West Region South West regional discussion board.
Lowering Loaded CO emissions?
Old Dec 29, 2011 | 02:45 PM
bluedevilinaz's Avatar
Car: 1984 Trans Am
Axle/Gears: 3.73:1
Hey guys,
I replaced my cat and got my smog pump working and my loaded CO is still failing at 4.43%(spec is 1.20)(1984 TA, Carb'd 305). Does anyone have any ideas for lowering it or be willing to come help me out as I'm out of ideas and almost out of time? Also, does anyone in Tucson have a CO meter I could borrow for a couple hours? I have to be out of town by Saturday at the latest as I start a new job on Monday in Cali. Thanks in advance.
Old Dec 29, 2011 | 10:06 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Lowering Loaded CO emissions?
Automax at Grant and Dodge (Richey actually) will set carb'ed engines for emissions.
Ask for Silver (thats the ASE Cert. Mechanic there)
Old Dec 29, 2011 | 11:45 PM
Car: 1984 Trans Am
Axle/Gears: 3.73:1
Thanks for the heads up on the mechanic but I figured it out. My timing was WAAAAAY off to the tune of about 3" before the BTDC gauge on the front of the motor. The genius before me never set it right apparently. I've now got the Loaded CO down to 1.95(from 4.43 before adjusting the timing, but after installing the air pump), Idle CO to 0.22 and the others down to under 100 so I just need to retard it a few degrees more and I should pass.
Old Dec 30, 2011 | 08:49 AM
Beater79TA's Avatar
If you're moving to CA, set the base timing to factory spec and get it tested. CA will check the timing when you smog it there and it has to be at factory spec unlike getting it to pass in AZ.
Old Dec 30, 2011 | 09:04 AM
Car: 1984 Trans Am
Axle/Gears: 3.73:1
Well I'm gonna cheat since I'm a "contractor" I don't have to register my car there as long as I keep my arizona drivers license and don't rent a house/apartment. I'm renting a room from a friend.
Old Dec 30, 2011 | 11:23 AM
Car: 1984 Trans Am
Axle/Gears: 3.73:1
It failed AGAIN!!!! Now I have to go spend $75 just for diagnostic plus whatever time and parts it takes to get the damn thing fixed and HOPEFULLY the shop can fix it. Otherwise I'm screwed 6 ways from Sunday. I'm at my wit's end with this damn car....
Old Dec 30, 2011 | 03:29 PM
Car: 1984 Trans Am
Axle/Gears: 3.73:1
Ok guys I need gelp asap! My carb is now so screwed up the car won't run! It keeps flooding out plus the plugs are shot. Any advice for easily rebuilding the carb (i have the kit) and replacing the plugs?
Old Jan 6, 2012 | 02:42 PM
Car: 1984 Trans Am
Axle/Gears: 3.73:1
I took your advice and went there after rebuilding my carb he got it to pass with flying colors for less than any other shop in town wanted to charge! Thanks again for the recommendation!
Old Jan 6, 2012 | 11:32 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Glad it worked out for you!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
