South West Region South West regional discussion board.
90' Iroc Vats
Old Mar 18, 2012 | 04:16 PM
melicious1's Avatar
90' Iroc Vats
Need help, Anybody out there tried the Bakerelectronix Vats bypass system? I've got a 90 Iroc, its been sitting for three years, won't start, I changed the fuel pump, fuel regulator, distributor. I have to manually start it @ the starter solenoid, it has 40 lbs, fuel pressure @ the shrader valve, but no injector pulse. All injectors OHM @ 16, if I shoot fuel in the plenum, it fires up for an instant.
Old Mar 18, 2012 | 09:56 PM
1bad71's Avatar
Car: 91 camaro z28
Transmission: turbo 400
Axle/Gears: 9/bolt
Re: 90' Iroc Vats
there is a relay behind the drivers side kick panel, near the floor, or right above the driver kick panel by the e-brake assy. there is a small gauge black wire going into it, cut this wire and put it to ground. this is the control ground from the computer for the starter relay. this should take care of your problem.
you can get a chilton book from autozone and it has the wiring diag showing you what im talking about if you need a reference.
Old Mar 19, 2012 | 09:55 PM
melicious1's Avatar
Re: 90' Iroc Vats
Thanks , I'll give it a try, is this just for the starter?
Old Mar 20, 2012 | 07:49 PM
1bad71's Avatar
Car: 91 camaro z28
Axle/Gears: 9/bolt
Re: 90' Iroc Vats
yes. for the starter. the injector power control runs through the pass key module also.
dont quote me on this! but i thought i was told that if you just jump the two wires that go to the pass key in the column togther, it runs?
Old Mar 20, 2012 | 10:09 PM
melicious1's Avatar
Re: 90' Iroc Vats
I ordered the vats bypass from bakerelectronix, should be here, by Friday. Gonna give it a try, also ordered the chilton book, local autozone did'nt have 1 in stock, should be here tomorrow. Thanx for the info, let you no how it goes.
Old Mar 26, 2012 | 01:41 AM
ChainHartMachin's Avatar
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
Re: 90' Iroc Vats
The VATS module actually generates a 30 hz signal to the ECM when the correct key is inserted (each VATS is looking for a specific resistance in the key). It also provides "ground" for the coil of the starter relay.
You can build a circuit using a 555 timer (there are schematics on the internet, which is what I used to build mine) to provide the 30 hz signal to the ECM in place of the VATS module.
Old Apr 18, 2012 | 02:25 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
Re: 90' Iroc Vats
IF THE ECM DOES NOT SEE THE 30HZ SQUARE WAVE EVEN WITH A CORRECT KEY IN THE IGNITION IM GUESSING THE ECM SHUTS DOWN FOR AT LEAST 5 -15 MIN AT LEAST...A BAD VAT MODULE CAN SHUT THE DOWN THE ENTIRE OPERATION. NO HOTWIRE IS POSSIBLE WITHOUT A SQUAREWAVE GENERATOR ??
Old Jun 17, 2012 | 01:30 AM
90_WS6_Formula's Avatar
Car: 91 Z28
Re: 90' Iroc Vats
take a meter to your key to determin the resistence... go to radio shack and get a resistor with the same value... splice this in where the VATS plugs in... if you do it right you can make a pig tail out of it and can remove it for added security
or you can close the circuit at the relay down by the kick panel and have someone remove VATS from the chip...
I had a 1990 Formula that was giving me hell with this and I did all 3. No more problems...
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 13, 2015 12:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
djmarch
Aug 9, 2015 05:27 PM
