South West Region South West regional discussion board.
help with decision on intake
Old Aug 2, 2013 | 10:48 PM
  #51
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: help with decision on intake
Originally Posted by Beater79TA
Or you could just buy the setup from EFI-Connection that provides everything you need to run a LS1 PCM on a Gen 1 SBC. The Dual Sync is nice but only works with the Accel DFI ECM.
Ah, I see. Have their web address? I looked up "EFI connection" and came up with 8 million hits... I always assumed that the dual-sync would work with other setups if wired correctly. Thank you for that info!
Old Aug 3, 2013 | 08:38 AM
  #52
Beater79TA's Avatar
http://www.eficonnection.com/eficonnection/default.aspx
Only issue I have with this is the cost. And that's only because I already have several LS blocks to work with and matching transmissions. If I had to acquire an engine too, this wouldn't be so bad.
FAST tried to build a setup that would use their version of the dual sync but never got it to market. Saw it in a catalog once though.
Old Aug 3, 2013 | 10:52 PM
  #53
Cool! Thanks!
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
IROCZ1989
Sep 4, 2015 11:54 AM
