Southern California Area Southern California Members.
Can an 86-up rear main seal >>
Old Jun 14, 2002 | 07:14 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
be changed while in the car? I know the engine needs to be lifted to remove the oil pan, but can those gaskets be changed without completely pulling the engine out?
Old Jun 14, 2002 | 10:55 PM
Russ-So Cal's Avatar
It is a one piece circular lip seal isn't it? You may not need to remove the pan, it might work to remove the flywheel, and replace it directly from behind the engine. Undoubtably, Don knows more about this than I do. Is your new motor leaking already?
Old Jun 14, 2002 | 11:15 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Exactly, unless you want to change the pan gaskets, you only have to remove the flywheel and back. On two-piece RMS's you had to even remove the rear main to replace it.
Old Jun 15, 2002 | 12:03 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Thanks guys, yeah, my engine has a small leak (has for a while) and now that it is not my daily driver anymore, I am going to fix all the small problems that have been bugging me. I plan to replace both gaskets since I don't know wich one is the leaker, and also put the Milodon road race pan on too. I have a ton of parts piled up around the house just waiting to go into the car, it just takes time. My Yukon has the same leak, so I should be pretty good at it when I am finished Thankfully the Yukons pan can be dropped without much trouble at all, nothing is in the way. The Camaro on the other hand....... You know, maybe that is why that guy had made the 4x4 out of his Camaro.. ? ..
Old Jun 15, 2002 | 01:16 AM
evil t/a's Avatar
Hmmm , does yours yhave studs or bolts holding the oil pan to the seal (2 bolts or studs)? Either way it would be MUCH easier to do it with a clear shot of the seal , they can be a pain to do . Also you should be using a one peice oil pan gasket , they are reuseable so you dont have to worry about that if yo dop the pan.
Old Jun 15, 2002 | 01:22 AM
evil t/a's Avatar
To replace the seal , assuming the tranny is out of the way.Leave the oil in , remove all of the oil pan bolts except the front 4 loosen them , the weight of the oil in the pan will pull the pan far enough away from the block for you to remove the seal .
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
