Super ram,, stuck cold start injector
The Super ram runner blocks off the cold start injector. Can we delete it? What do we do. drill it? what about the cold start injector line it is too short to fit aroud the runner an go where it needs to go. Im sure some one has ran into this problem. What do i do.. I can get a diffrent fuel rails if it is possible to delete the cold start b/c these rails have a plug over that end there.. So im stuck till I find out what we can do with the dam injector. help...
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Unplug it from the back of the fuel rail, and put a plug in there to replace it. Problem solved.
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
You don't use the 9th injector with the super ram. Un screw the injector tube from the fuel rail and cap it. I bought a cap for under $25 (i think). I'll look for the rct and post later.
Also you won't use the connector. Just move it out of the way.
Thanz buds
I got the super ram on last night after I found out from here.. Ya Dwane if you could guide me in the right direction where I can get a cap like that.. That be Great..
Thanks..you 2..
Thanks..you 2..
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
I got mine from Steet&Performance. You can go to there website at www.tunedport.com but like you mentioned, I don't think its on there site. You'll have to give them a call at: (501) 394-5711 My total bill was $26 for the cold start plug, fuel rail plug and shipping
need the car running asap. I will never for get this =) thanks every one..
