Southern California Area Southern California Members.
Stealth Ram vs. Siamesed TPI Intake Dyno Numbers
Old Nov 6, 2002 | 09:57 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
http://www.eecis.udel.edu/~davis/z28...age021105.html
Old Nov 6, 2002 | 10:25 PM
Guest
Guest
Posts: n/a
I am absolutely convinced that Mike Davis is totally off his rocker...
:hail:
Old Nov 6, 2002 | 11:15 PM
Engine: 3.6L
nice numbers but I don't like the fact that you have to ring it out like that (SR). He should have track numbers within a few weeks. At his site he also has pics of a single plane EFI intake, so maybe he will have tested all the option for us.
Old Nov 6, 2002 | 11:41 PM
Guest
Guest
Posts: n/a
I think its funny he was making peak HP with the siamese base at 5200. I never did get my dads car back to the dyno, but it looked like the HP peak on his car would have hit something like 5600. Pretty high for a TPI. I really gotta get this beast back to the dyno.
He needs to add the miniram to that chart, save me the effort
Old Nov 6, 2002 | 11:49 PM
Engine: 3.6L
I guess this is his only comparison with a miniram he borrowed for traxion.
http://www.eecis.udel.edu/~davis/z28...age010511.html
Old Nov 7, 2002 | 02:14 AM
BrandenCali's Avatar
dyno this
now thats a beast
Old Nov 7, 2002 | 02:19 AM
another
Must be running now 600 hp and guess Gene still finsishing the final touches. 600hp dyno run bad results Gene was not happy.
Old Nov 8, 2002 | 10:43 PM
Guest
Guest
Posts: n/a
He got track numbers. 11.83@114.3
Old Nov 8, 2002 | 11:49 PM
Yeah Not so good
With his other set up he said he got 10.70 So something is not right still, He should be getting consinstent 10.70 or better now. He did a lot of work to the car. Got a lot of new stuff. I think maybe he got that 11.83 with no bottle maybe?
Old Nov 9, 2002 | 12:16 AM
Engine: 3.6L
no, Madmax is talking about the stealthram setup. Those are some good numbers, but I wonder what gears he has in there. I'm sure the 6400 RPM power peak and more optimal gears will net better results.
Old Nov 9, 2002 | 12:24 AM
Guest
Guest
Posts: n/a
10.70? No, Mike Davis' car has NEVER seen a 10.70. Fastest he went before was 11.94@111.5 with a siamesed base TPI. This was his first run with the Stealth Ram, though it looked pretty decent.
He has a LT4 Hotcam, AFR190 heads, and ZZ4 shortblock thats seen a couple rebuilds because of mishaps. I think he is running SLP 1 3/4 headers, auto tranny with Vigilante 2800 stall. Not sure on gear... 3.73? Or 3.42. I can look again.
3.73's. 255/50/16 BFG DR's
Old Nov 9, 2002 | 02:13 AM
oh i was looking at that post
hehe sorry my bad, I seen those numbers and said wait a minute there the same That set up of those Pictures there Is Gene's I believe those pics where his old set up, with afr 195's I think not sure, But now he has Afr 210 I think. So Mike did pretty good with that set up thats for sure. Gene is looking to see some 9's but he is not sure if he will get them soon. He still needs to drop some more weight, like pull the tank.
1992rs/ss
Jan 31, 2025 05:10 PM
1984HO
Mar 19, 2021 11:59 AM
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
