How to set timing
Car: 87 z28
Engine: 5.0
Transmission: t5
How to set timing
How would i go about setting the timing ON MY 87 z28 with a 305 and a carb if you need any more info please ask Thank you.
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Disconnect the inline four prong connector that runs from the distributor (located on the driver's side, by the engine-tranny mount flange), loosen the hold down bolt (9/16"), turn on the car, using a timing light ... adjust the distributor for the preoper timing.
This applies to carb'ed V8 3rd gens only, TPI/TBI are different.
1-8-4-3-6-5-7-2
looking from the front
8____7
6____5
4____3
2____1
On my distributor cap there is a line between where cylinders 1 and 2 connect. IIRC counter-clockwise will advance the base timing.
8____7
6____5
4____3
2____1
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
IIRC - if I remember correctly
TIA - Thanks in advance
The best timing would be as much as you can get without the car pinging. Usually thats around 8-10 degrees initial. Dont forget to set it back to stock when you go in for your smog check.
Yeah, the most you can advance the timing without the car pinging. If you advance it too much the spark plug will fire while the piston is still travelling up on the compression stroke and it will "knock" or "ping." Same concept as preignition, going off before it's supposed to basically
