Southern California Area Southern California Members.
Problem...
Old Feb 24, 2004 | 08:31 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Problem...
My car has been acting weird. It will bog when I accelerate but as soon as it hits 2000 RPM it regains full power. It's almost like a nitrous shot at 2K RPM. Under 2k its boggy. Doesn't seem to respond no matter how much gas I give it the car responds the same way. Funny thing is that it doesn't do it all the time. It can go for days and act normal but out of the blue it will start with the problem again. It's only started doing this in the last couple weeks. I am completely stumped. What could be causing this? Is it a bad sensor or something? I don't have a cat on the car so I know its not a clogged cat. Oil pressure is normal so is engine temperature. It will idle fine as well. Please someone help me out I don't need this right now. This is making driving in the rain very dangerous since the sudden power recovery at 2k causes the back end to slip. Any advice? Thanks ahead of time for any help given.
Old Feb 24, 2004 | 10:33 PM
Guest
Guest
Posts: n/a
Cold weather and humidity level.
Sounds like it needs some tuning.
Old Feb 24, 2004 | 10:38 PM
trans87's Avatar
Hmmm that's a thought. You think the weather would cause it to act that bad? It's funny how it goes back to normal for a few days too. Man its bringing back horrible memories of the demon my car had before the engine swap
Old Feb 24, 2004 | 11:08 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Just a guess...could it be the distributer advance sticking then releasing? Checking my cap & rotor the other day it looked like things could get a little rusty in there if not checked Periodically.
or maybe a buggy chip.
Old Feb 25, 2004 | 01:45 AM
Guest
Guest
Posts: n/a
There's no advance in there to stick.
All electronic...
Old Feb 26, 2004 | 02:48 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
When Don did the motor did he change out the egr valve what could be happening is its getting stuck open then at 2000 rpms slams closed so try unpluging the egr solenoid for a few days all you will get is a light maybe it will not hurt performance its a try
Old Feb 26, 2004 | 05:03 PM
trans87's Avatar
Actually the EGR is blocked off due to the ZZ4 heads not having EGR. I am going to go check to see if any plug wires are burnt but the rain is currently making that impossible. This problem is really irritating.
Old Feb 27, 2004 | 12:05 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Oh yeah forgot about the heads well try that if you need any help tomarrow after 5 im avalible if you want me to cruise out and you can check out my GTA just give me a buzz or leave me your # and I'll call you after I go pick up my new bmr lca's
Old Feb 28, 2004 | 02:26 AM
BrandenCali's Avatar
Check out this updated post..
https://www.thirdgen.org/techbb2/sho...hreadid=225853
I believe it is plug wire month.. Well you heard my story..
Old Feb 28, 2004 | 12:32 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Nigel, Rusty and I will be working on our cars this afternoon at my house. Just give me a call if you want to cruise out.
909-238-3774
Old Feb 28, 2004 | 09:34 PM
trans87's Avatar
Sorry guys I have been working so I didn't get a chance to check the boards. This problem is getting really annoying and its getting worse. When it bogs its backfiring through the intake. Sometimes it bogs so bad the car dies. Funny this is the idle will be ok maybe a little rougher than usual but the bogging doesn't really happen until you press the gas. All my plug wires look normal so I don't know what the hell is going on. I swear as soon as it hits 2k RPM it is completely normal. Anything above 2k will be no problem. As soon as it dips below 2k it will bog. Then some days the car will be normal, like nothing happened
My number if you guys need to reach me is 714-931-2169
Old Mar 22, 2004 | 09:25 PM
trans87's Avatar
Update!
Problem solved. Car threw out a code 51 which is a prom/ mem cal error. Don threw in a finalized chip and I haven't had a problem since. Thanks to Don, Rusty, and Branden for helping me out with solving this issue. Nice to have the car running smooth again with no problems :rockon:
Old Mar 23, 2004 | 06:24 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Glad to hear you figured it all out
Old Mar 23, 2004 | 07:17 PM
Cool so problem solved.. Don't for get that the Iac needs reset correctly now..
Old Mar 23, 2004 | 10:14 PM
trans87's Avatar
According to the IAC manual and the car manual the IAC resets itself at 40 mph after install. I don't think there is any manual adjustment needed other than making sure when you first put it in that the needle is sticking out more than 1 1/8th inch. Other than that no adjustment is needed. I could be wrong though. So far the car acts exactly as it did before the problem.
barbiek9
Sep 3, 2002 04:24 PM
FLYNLOW92rs
Aug 30, 2002 12:17 AM
Philou
Aug 18, 2002 01:29 PM
Blaze of Glory
Nov 20, 2001 10:18 AM
