Sc3g board down?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Nick's server died for good this time. He has a new server up now, but Bret and Frank need to move everything over to it and update the links.
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Car: 90 RS / 89 IROC
Engine: 305 TBI / 305 TPI
Transmission: 700R4 / T5
Axle/Gears: 3.73 / 3.08
I haven't heard anything. Was everything saved? Someone email me please. I need info for the new server also.
I still cant find the login info... But none of my code needs to be changed. As long as the domain name is set and the data and database made it to the new site, it should work. If I need to upload it again, I need to get the login stuff from you again. I moved and can't find anything still. As for the database, if there wasn't a more recent backup than mine, we will lose a little bit of stuff.
Car: Yes...
The URL is now working, but all that loads is a blank page. If Nick's server flat out died, then everything is probably lost and the site needs to be reloaded onto the new server.
Car: Yes...
Originally posted by RWB____s
Why dont we stay here until it is completley debuged . the last one didnt work very well to begin with.
I still need to give him a revised logo/header that will work with the new width. Once everyhing is back up and running, we should try to use the site as our main source of communication and TGO as a back-up.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Starting over
Originally posted by Russ-So Cal
I finally got in enough posts to be a "senior member." Does this mean I go back tobeing a "newbie?"
Car: Yes...
Originally posted by madmax
Not the first time this has happened. Between server crashes, moves, security changes... and its still not working right now. I guess I dont understand having a 'main' site that people dont want to go to, and is down quite often.
Frank pretty much donates his time to maintian the site. Nick hosts it for us for FREE. If people want to **** and moan and complain, then come up with a better solution or get out your checkbook.
We could have a real fancy, bang-up site, with a fast server, trick message board ...and so on, but it costs money. And that's MONTHLY money.
Car: Yes...
I hear ya and I know the deal, but I have seen posts where people are wondering why more dont go to that site. If you wanted a reason...
Elephantismo
Feb 13, 2019 12:51 AM
Linson
Oct 1, 2015 09:50 PM
