Irwindale Raceway 1/8mi
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Who's going next Thursday(12-22-04)?
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Hi Vincent
I'll be there. Not sure what time as I have an appointment at the DMV to renew my drivers license at 2:00pm. Should be there by five for sure if not earlier. Seeing how things go I may go the next Thursday also.
I have to get a lot of practice in. There's this red Camaro that runs around 110MPH and mid 12's in the quarter I have to catch. :hail:
Hopefully others can make it. I would like to see how Brandon's car will do. Dave Fisher's car is running better than ever with another tune up from Don. Kevin and Don are getting their cars dialed in. Allen
Originally posted by 1989GTATransAm
Hi Vincent
Hi Vincent
If I go I'm just going to watch. The best time to get there is around 4:00. After 2 hours you will get at least 4 runs.
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
Originally posted by 12secSS
So you are renting out the track? Irwindale Dragway won't be open until January 6th, they have two weeks vacation now. No more drag racing around So-Cal until after January, except for the Hangovers.
RATS! Oh well. Hey Brandon any leads on place to dyno tune our 3rd gens? Allen
I really want the car to be running at it's best.. I do want to make this car as another Rocket aka Mike P.. His car inspired me.. I seen it in action many times.. And I thought if I could get some more power and good derivability. And Now is the time to start building the suspension more than I have.. Then The Red Roc could perform just as good but in both worlds hopefully.. I drove to Bakersfield in The Roc a few weeks ago and it pulled the grape vine very strong..
Let's hope Gene has some ideas. Thank's Brandon for the follow up. Allen
Hey Bradon, you don't need a dyno to tune your car. It is much better to tune it either at the track or on the street (which ever you do the most). You want to use an envirment that is as much as real world as possible. Dyno tuning is only for peak numbers and dyno queens. Just get a wide band O2 and start logging data, this will net you the best results throughout your power band! JFYI.
Car: 1989 GTA
Engine: 369 TPI
True. However I would like to get another bench mark with a dyno pull. I have one before I started the lastest rounds of modifications. I feel we are pretty close to the right tune at this point. It will also give me an idea what my shift points should be with the new combo.
Then there is this red Camaro that I'm trying to catch.
Allen
Allen Supreme Member
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Originally posted by ReddRocket
I truly miss the RR to the extent that I am currently in the process of building another (my 4th) third gen. I can only hope that this one is half of what the RR once was.
I fully understand what you mean Gpl.. The car is a every day driver.. And it needs to operate good in the City..
But with this Dfi.. I can fully tune it out for when I want the car to be running fully tuned for like the track..
I can easily swap the 7730 tuned ecm in and have that for everyday use.. because the dfi is plug N play..
Rick89IROC
South Central Region
Feb 28, 2002 10:08 AM
