Southern California Area Southern California Members.
Plug Help
Old Feb 24, 2005 | 11:06 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Plug Help
Hey guys I need to know what kind of Spark Plugs work well in the L98 350 tpi I am going to the track for the first time tomorrow and i want her to run good right now I have bosch platinum's
Old Feb 25, 2005 | 01:14 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
They're fine
Old Feb 25, 2005 | 11:43 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Just make sure they are gapped correctly and the tips are on securly - I have had problems before with both the gapping and the tips right out of the box.
Also IMHO would stay away from Rapid Fires
Good luck at the track
Old Feb 26, 2005 | 05:57 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
You are good to go. The Bosch Platinums are good plugs. Stay away from Split Fire.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
