Southern California Area Southern California Members.
New Torque Arm
Old Aug 23, 2005 | 08:54 PM
JERRYWHO's Avatar
New Torque Arm
Time to try a new torque arm, Much shorter and lighter then the Global west Trac-link in the car now.
Jerry
Old Aug 23, 2005 | 10:33 PM
Guest
Guest
Posts: n/a
What does it attach to?
Besides the diff... of course.
Old Aug 23, 2005 | 11:21 PM
JERRYWHO's Avatar
The floor pan.
The Global west track link is 44" long, This one is 38" long.
Old Aug 24, 2005 | 01:46 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Looks nice. did you build it or is it a jegs? Its almost identicle
Yes the global weighs a ton and it does not adapt to different transmission swaps since its designed strickly around factory crossmember locations. The reasons why I got rid of mine and went to a spoon er spohn. (changed trans to tremec tko).
Old Aug 24, 2005 | 02:15 AM
JERRYWHO's Avatar
Jegs
Old Aug 24, 2005 | 11:31 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Looks good, I assume you switched for additional clearance for your new kick *** exhaust setup?
Old Aug 24, 2005 | 11:32 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Was the weight savings significant enough to mention? I know the Global West piece does appear to be quite beefy
Old Aug 24, 2005 | 02:01 PM
JERRYWHO's Avatar
The Global West Trac-link is 40.5lbs and the Jegs Torque arm is 23.4lbs. Now the car is in the 2900s I hope this 17lbs with a few more things will get it in the 2800s
List of new stuff
17.1 New Torque arm
42.0 New 9 Bolt rear end with lower gears
18.0 New exhaust
28.0 New seats and mounts
7.6 Hood latch and headlight bar
112.7lbs Total
This will get me deep into the 2800s and then someday a new motor that is 110lbs less and you have it a mid 2,700lbs street car.
Jerry
Old Aug 24, 2005 | 04:06 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
List of new stuff
17.1 New Torque arm
18.0 New exhaust
112.7lbs Total
Jerry
Awesome -
Old Aug 24, 2005 | 07:34 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Jerry, ever thought of making an exhaust of Titanium?
reason im asking is because my friend just bought a full 3" titanium exhaust, muffler included for his WRX STi... man that thing is the lightest metal i have ever held... i mean you can hold the entire exhaust from header flange to muffler with 1 hand..
Old Aug 24, 2005 | 07:57 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Hey Dave, don't give Jerry anymore ideas. Now that is one I can use. Hehehehehe.
Old Aug 24, 2005 | 08:30 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
yeah that metal is awesome... my wedding band is titanium, its awesome stuff..
Old Aug 24, 2005 | 08:51 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
So, have you taken a hole cutter to the car yet?
Old Aug 25, 2005 | 12:09 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Although we have never really met, I can tell (Jerry) you are a man with waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay to much time and money in his hands! I look forward to seeing this work of art in "MANY' car magazines and on a power tour. Now if your public can talk you into going into production on many of those Hi-tech pieces you have so engineered to impress and with hold from your demanding public only to tease us with little glimpses. (its like moving a glass of water just out of reach of a dieing sun scorched mans hands every time he reaches for it)
You are the great camaro *** that your people have been waiting for! We all bow down to your ultimate supremacy and *** hood for you are truly the savior of the third gen world!
I know flattery and *** kissing will get me nothing but my teeth kicked in. Im ready for the flames!
Old Aug 25, 2005 | 12:27 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
I would like to be around for the lite show if a titanium exhaust system ever strikes the ground going of a bump And it burns so good when it lites off. just like magnesium.
Old Aug 25, 2005 | 12:58 AM
JERRYWHO's Avatar
No way, I don't do mag cars anymore.
Jerry
Old Aug 25, 2005 | 01:11 AM
JERRYWHO's Avatar
Titanium will not burn like magnesium, and yes I have a number if Titanium parts on the car.
Old Aug 25, 2005 | 01:20 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
I have seen it. I use to work with it daily. Seen what a red hot piece of metal thrown carelessly into a titanium chip gondola will do. It burns real nice. 20+ years in aerospace programming and machining exotic metals. Don't believe? try it. Get a nice 55 gal drum and fill it with titanium chips and then take a red hot piece metal and toss it in. Better have the fire dept handy.
Old Sep 13, 2005 | 02:22 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
In that regard, aluminum has similar properties. Powdered aluminum is a component in many rocket fuels and I know the military uses it some bombs, daisy cutters come to mind.
Old Oct 3, 2005 | 09:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
so jerry, you've had it for a bit now.... update on the arm? was it worth drilling thoes holes in the floorpan?
i want it, but everytime i goto order it, i hesitate because i know once i drill thoes holes to put it on, theres no going back.. mines a street car first, and i dont want anything that makes noise, causes quirky handling, ect... would you reccomend it for a street car?
it effect your 60' any?
Old Oct 3, 2005 | 08:15 PM
Car: 1989 GTA
Engine: 369 TPI
Same question with same reservations. I was thinking of buying your Global West unit but the weight difference is giving me pause. I understand the factory unit only weighs 15 pounds. Waiting on your report. Allen
Old Oct 4, 2005 | 10:48 AM
Russ-So Cal's Avatar
The properties of powdered metal are totally different than a solid piece. Fill that 55 galolon drum with machined aircraft parts, and throw all the red hot steel at it that you want to and it won't light off.
Old Oct 4, 2005 | 12:08 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Im talking about titanium/magnesium "machining chips" You may get powder from a water jet residue, and chips from milling or turning machines. Solid Titanium, Magnesium material "will" lite off with enough heat and it will take more than just throwing "a" piece of red hot material at them. Machine chips will lite off at a much lower heat threshold than solid material. When maching "ti" or "mag" you "have to" have special fire equipment handy to put out any "ti/mag" fires.
Been machining for many years and know what Im talking about.
Old Oct 4, 2005 | 11:19 PM
So why would you think a titanium exhaust pipe would light off if it scraped on the pavement going over a speed bump at a crawl?
Old Oct 5, 2005 | 02:01 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
what I ment is most exhibition wheel stand cars have small amounts of "ti" on their wheelie bars to put on a "Spark light show" for the crowds when they are on 2 wheels. Im sure you seen it at the drags. Thats what they use.
So if you also had a titanium exhaust and it scapred the ground "hard" enough it would lite off and have a small light show under the car. It would take alot (like a major car fire.) to get it to "burn". Once it does tho, you can kiss that sucker goodbye. I 've seen a titanium fire burn right through the machine bed of a milling machine. It burns that hot. You cant put it out with basic fire extinguishers. It takes special chemicals to smother the fire. Magnesium is very very much the same way.
I hope this clears up your question
Ron
Old Oct 9, 2005 | 12:03 AM
demonchild's Avatar
shorter torque arm
im sure this has been gone over many times, but i thought i would ask anyway.
Why cant a deal like what is on the 05 mustang be used?
Old Oct 9, 2005 | 12:33 AM
demonchild's Avatar
well i found a post.
https://www.thirdgen.org/techbb2/sho...ght=05+mustang
however, everyone bashed the setup and made no real progress toward explaining why it cant be used on fbodys. I think Dean came the closest to explaining it.
Old Oct 9, 2005 | 03:45 AM
v6#21's Avatar
Well, Dean here again, just under a different name this time.
The reason why you can not use a third link like the one pictured is because we simply do not have the room under the chassis above the diff and driveshaft tunnel to add one. It is all about chassis design and strength points. Certainly you can torch out that area (and loose your back seats) and weld in custom bracing provisions for an upper third link chassis mount that would have the proper length and geometry to work. It basically would involve a larger hump between the rear seats of a third gen and good custom chassis (floorpan) rigidity on the new humpp section to control for and aft pressures.
Old Oct 9, 2005 | 11:45 AM
Car: 1989 GTA
Engine: 369 TPI
Hmmmmm. Maybe install one where the existing 3rd gen one goes. Only it would bolt to the top where the two bolts go down through the pinion area. Then extend it to the existing transmission mount.
Then what would be the benefit over the existing 3rd gen style such as the factory, Global West or Spohn units? I already have in mind what one would look like if it was of benefit.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
