Dyno Don
Dyno Don
Dyno Don, are you still in business? I've been trying to reach you by phone, but no luck.According to the TBI board I need some timing adjustments in my chip. This is on a 95 Truck, 350 with Vortec heads, 5 speed.
Thanks, Walt
Thanks, Walt
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Thanks, Walt
Thanks, Walt
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
'95 Trucks use a different chip than 87-92 TBI's. '93 to '95 use a MUCH better computer, almost as good as the TPI.
Yes I know, it is a 16197427 which seems to be a problem since 350's with a manual did not use this computer. Does this mean you can't help me? The person that did the chip for me does not want to play with it anymore since it runs pretty good even though the mileage went to pot.
Yep, I can help. That computer uses a $0D bin, which we have.
Are you available on Sat the 15th?
LT1Formula
20
Nov 14, 2015 12:02 AM
