Southern California Area Southern California Members.
Rad flush; check engine lite comes on
Old Sep 3, 2007 | 12:18 PM
Parrydise7's Avatar
With this heat we are having I flushed the radiator and put in some fresh antifreeze. I also changed the thermostat. I got the thermostat at the dealer and I previously had a 195. The dealer gave me a 180.
Shortly after starting, the check engine light comes on. Questions:
1. Is this likely related to the 180 thermostat? (the engine runs noticeably cooler);
2. Is the computer going to learn and stop turning the check engine light on?
3. Is the car going to quit on me or go to limp home mode?
4. Should I bite the bullet and install a 195?
Thanks!
Old Sep 3, 2007 | 04:16 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Re: Rad flush; check engine lite comes on
I dont think that it has anything to do with the thermostat... I personally dont even have a termostat in my car, and I havent gotten a check engine light for it
-Tim-
Old Sep 3, 2007 | 04:21 PM
Guest
Guest
Posts: n/a
You need to check the code and see what it is.
Old Sep 3, 2007 | 04:54 PM
Parrydise7's Avatar
Does it make a difference if it is a soft code?
Old Sep 3, 2007 | 08:03 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You must have knocked something loose.
What he said, check the code.
Old Sep 3, 2007 | 09:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You bought a thermostat from a dealer? What'd that cost you, about $20? They're $4 at any auto parts store.
The code is probably related to the coolant temp sensor. Its the closest thing to the thermostat housing and you probably knocked it loose.
Old Sep 4, 2007 | 12:53 PM
Parrydise7's Avatar
Thanks, everybody
Isn't it amazing that a tiny hose, not much bigger than a toothpick, that I can barely see (even with my glasses), can cause so much trouble.
After Kevin's comment, I guess I won't even say anything about buying a $20 paper clip.
Infested
May 22, 2018 11:56 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
