Southern California Area Southern California Members.
I'm elated about....
Old Nov 25, 2007 | 02:55 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I have my 3.70 9-bolt factory gear rear end installed and it's "QUIET" I'm totally jazzed.
Old Nov 25, 2007 | 06:40 PM
Guest
Guest
Posts: n/a
Re: I'm elated about....
Well thats cool so the factory gear is quiet, and aftermarkets are noisy?
Old Nov 26, 2007 | 03:01 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
yup that's why Don been looking for a BW ring and pinion set because all aftermarket gear sets are noisy and most likely are made by the same manufacture
Old Nov 26, 2007 | 11:12 AM
Russ-So Cal's Avatar
Are you going to leave the 9 bolt in, or is it a temporary fix until you get that 12 bolt done? How close are you on your 12 bolt?
Old Nov 26, 2007 | 12:40 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Congrats Don!
If you can beef up the 9-bolt to hold the power, it is the better option. Going to 12 bolts or Ford 9" will be stronger, but there is always a performance penalty to be paid to have to move the extra weight.
TA
Old Nov 26, 2007 | 02:17 PM
Dyno Don's Avatar
Temp for sure
Old Nov 26, 2007 | 08:41 PM
TA's Avatar
TA
Axle/Gears: 9bolt
...so, that means more HP is on the way, as if that were a surprise to anyone who knows Don.
TA
Old Nov 27, 2007 | 12:06 AM
Dyno Don's Avatar
TA
You bet!!!
Old Nov 27, 2007 | 12:54 AM
leo037's Avatar
Car: 92 RS with B4C Package
Axle/Gears: 323
Hey Don, Are Motive Gears any good? I was thinking on buying a set for my 9 bolt?
Old Nov 27, 2007 | 09:29 AM
So far no one has found any gears for the 9 bolt that are quiet except for the original factory gears. As was mentioned in a previous post in this thread, all of the aftermarket gear sets seem to be made by the same company and then packaged in different company's boxes. So far no one has found a quiet set of after marklet gears.
Old Nov 27, 2007 | 10:36 AM
Dyno Don's Avatar
That's right, I got the last set from Motive. They made noise.
Old Nov 27, 2007 | 02:14 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
That 9-bolt, the "Aussie" piece, is that the similar or the same as the late model GTO runs? I heard that it was. Does anyone know why the gears don't fit our 9-bolts from those?
I'm asking because at least you can buy those gears from GM...
Old Nov 27, 2007 | 10:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The GTO uses an IRS setup, that's all I know. I would think that makes the differential different.
Old Nov 27, 2007 | 11:01 PM
I think it depends entirely on how the differential is set up. It could be that the the housing changed to fit a grease seal at the sides of the banjo with the same spline as our cars. Then it would use short stub shafts to the inside u joints. That is such a sensible way to do it that I'm sure GM modified everything just to make things difficult for us and to do one more thing to try to force us to trade in our cars on what ever new piece of junk they want to sell us!
Old Dec 1, 2007 | 11:42 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I have had my Precision gear 3:70 's in my Camaro for quite a few years now, never has the rear end made any noise....? I am guessing there to be roughly 5000 miles on them and a good 100 passes down the 1320, still no noise....I don't remember where I bought them from, I think it was Randy's ring and pinion, but I am not positive on that, that was a long time ago.
Jason
Joe Tag
Members Camaros
39
May 11, 2014 10:44 AM
Dyno Don
42
Jan 6, 2010 09:54 AM
airman1952
Carburetors
Apr 3, 2007 08:06 AM
1MeanZ
May 29, 2006 11:49 PM
ck76239
Nov 30, 2005 01:23 PM
