anyone here?
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
anyone here?
interested in a short block sbc 355.
.030 over
comes with water pump
new starter
oil pan .
oil cooler
valve job on cast iron heads
forged speed pro pistons.
comp mild cam
and high volume oil pump
one slight problem has one bent rod
engine has low mileage as u can tell
neighboor has been lookin at it..
600 obo
for more info on the cam and heads pm .
local pick up .if anyone is interested
.030 over
new starter
oil pan .
oil cooler
comp mild cam
600 obo
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: anyone here?
You would have better luck fixing it first.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Re: anyone here?
it isn't hard to pass any 5.7 the legit way.. with your egr and air system and tuning emissions wont be a problem. i can send u specs on the cam.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Re: anyone here?
well if anyone is really interested its here..
i wouldnt want to do a efi swap for this block . id rather do a carb set up
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: anyone here?
If its a roller cam, hell yes. He said its a mild cam. I can make almost anything pass CA smog with my tuning. Its not that tough if you plan it and ask us questions first.
