any one converted a 305 l03 tbi to a tpi??
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
is there any special mods? is it hard? or its just about swapping the plenum? is it complicated wiring? anything will help!i want to know because my motor is a bit modified(aluminum heads high lift cam msd ignition headers etc.) and the thing is that its TBI n i cant find a perfomance tbi anywhere! people tell me to put 350 injectors but i dont see any difference just a bit a BIT faster(unless its my imagination) any advice will help...thank you
Car: 1987 Chevrolet Camaro
Engine: Vtec Killer
Transmission: the kind that loses Hondas in 1st.
Axle/Gears: the kind that turn the wheels
Re: any one converted a 305 l03 tbi to a tpi??
The wiring is a BEatch... Just go Carb. If u decide to got tpi I have a manifold up for sale.
Engine: 5.oh tpi
Car: 91 Z28
Engine: LB9
Transmission: auto
If you are going to keep the TBI start reading on the TBI board, there are pages and pages of good info. For performance tbi's you can check out ebay and look for some 305/350 tbi's that have been bored out which would bring it to a bore of 50mm. Another option is to find a 454 tbi either on ebay or the JY which starts at 50mm and if you needed more airflow you could have it bored as well. Here's a local company that has performance TBI stuff http://www.turbocity.com/default.php?cPath=16_29. You will also need to either run a carb manifold with an adapter plate or have your tbi manifold bored to clear the oversize butterfly's in addition to lots of computer tuning.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I've done so many I have lost count, but it's not a cheap swap.
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its more than just swapping the plenum, you have to swap the intake manifold too. And get a new computer and re-wire the wire harness. There is a sticky post in the TPI forum, as well as a tech article in the Tech Articles section of the main page of this website to help you get started.
Its definitely worth it. When Don did the swap on his former 92 RS, he gained 17 HP and 70 TQ at the rear wheels. And that was a stock engine. You should gain even more.
Engine: 5.oh tpi
The answer to your question depends on a number of issues. For instance, do you have all the parts for the swap?
Once you've collected all the parts, take a number and get in line. You don't want anyone but Dyno Don doing this swap.
This isn't a swap for amateurs.
Engine: 5.oh tpi
aw man i guess i should LOL!!
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I also want to do that swap on my car you should as birdtojag he was gonna guide me but my harness is not complete
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
dont forget fuel pressure get ready to take that tank down and open it up youre going to need a new sending unit, one out of a v6 MPFI will work and youre also goin to need tpi fuel lines, they do sell piggyback harnesses to convert tbi harness to tpi, in my opinion adding a cam and a 3.73 posi in the back should wake up that L03 also Holley TBI Throttlebodies seem to look good your also going to need to change the throttle and kickdown cables and if you want to keep crusie control, one of them too
Car: 1990
Axle/Gears: stock
look when you get the tpi make sure you get the full wiring system. that means every wire to the firewall and behind the firewall.
and i mean every wire.
not one cut wire and no aftermarket wires.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
My tpi harness that i have does have some wires vut but thats why i am looking for another one can i just buy one from painless
Car: 1990 Camaro RS
Axle/Gears: Posi
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
If you are absolutely sold on going TPI vs. TBI which you currently have, I would have to try to dissuade you. Stick with TBI, it's pretty much like a carb already. There are tons of aftermarket performance parts and services for TBI, and unless you have a deep pocket and high tolerance for extensive tuning, don't try this conversion. That's my opinion, take it or leave it. In any case, good luck with your camaro!
Car: 91 Z28
Engine: LB9
Transmission: auto
+1 on the TBI build up. For the money you're going to spend on the conversion you would be half way to getting a complete TPI car. Then you could have one of each.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Engine: 5.oh tpi
ive taken them to my house for inspection and still i get complaints
i just dont want to lose the pakage
-thanks
Car: 91 Z28
Engine: LB9
Transmission: auto
Engine: 5.oh tpi
just checked it out!
and im convinced...i think ima go for the purchase!
hopefully this will let the hidden beast out of my car....since its always givin me issues since the modifications....
cant wait!
I've also never heard of anyone who swapped their thirdgen from TBI to TPI and regretted it.
Engine: 5.oh tpi
In theory a modified TBI injection system can support more horsepower. That would be with larger bore throttle body, higher flow injectors, higher flow fuel pump, and higher pressure regulator.
Of course it won't make more horsepower than the engine is capable of.
Car: 1989 iroc z28
Engine: 305(5.0) sb400 in works
Transmission: 5spd
Axle/Gears: 3:42 posi disc brake rear end
there is a difference in intakes first of all 86 and down and 86 and up the 4 middle bolt holes are on a different angle so 86 and down tpi's need 86 and down heads and 86 and up tpi's need 86 and up heads.so dont get caught with that dilema i learned the hard way.the wiring harness and computer has to be changed as well.not hard just tedious.still in the process of conversion so havent run across any more issues yet hope that helps
But it all the same.
