Southern California Area Southern California Members.
just put on a set of 20" beyern bmw wheels on my car..
Old Mar 15, 2010 | 01:49 AM
cintegra2003's Avatar
Car: 85 z28
Transmission: auto
im gona lower it in about 2 weeks...how much do you guys think i should lower it since they are 20" wheels?
2010-03-14201846141.jpg?t=1268635853
2010-03-14201846491.jpg?t=1268635882
2010-03-14201824541.jpg?t=1268635912
Old Mar 15, 2010 | 01:59 AM
Stephen's Avatar
Car: 87 GTA
Re: just put on a set of 20" beyern bmw wheels on my car..
Definitely lower it. It is now riding as high as my Suburban did!
Even better.....Take them back & get 17"s or 18"s max. Look too big & make the car ride too high.
Old Mar 15, 2010 | 02:00 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
I like them.How did they fit on the front? Did you need to use a hub centric ring? I would lower it in the front an inch or two then go from there.
Old Mar 15, 2010 | 02:07 AM
Car: 85 z28
Transmission: auto
i have 18" boyd coddingtons but just wanted 20" wheels too .im a wheel *****..lol..yea i used hubcentric rings and i was thinking about 1.2" lowering springs...
Old Mar 15, 2010 | 02:13 AM
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
I feel 1" would do just nice.. Would give it a nice stance yet enough room to give it a decent feel. Allowing the space in the wheel well to travel north and south...
That's a real smooth lookin' car brotha! Anymore pics??? I too am a ***** of pics.. lol!!!
Adrian
Old Mar 15, 2010 | 02:17 AM
Car: 85 z28
Transmission: auto
Adrian
thanks bro!!!!ill post up pics later or when i lower it..
Old Mar 15, 2010 | 04:50 AM
Twin_Turbo's Avatar
A set of Eibach Sport Lines will make it perfect. Ignore the haters who always chime in with their 17s and 18s. 17" wheels went with the dinosaurs. The tire selection is not nearly what you can get for 18 and larger and if you run a wide rear tire the aspect ratio selection is small and this often means you end up having a taller sidewall on the front than on the rear, talk about UGLY!
The nice thing is, you will have a little ground clearance over the smaller sizes without the car looking jacked.
My buddies GTA w/ 20s and sport lines:
Here's another buddies 88 w/ 18s, they are too small IMO (I have those wheels in 19"...he ripped off my styling idea LOL)
Old Mar 15, 2010 | 10:52 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Yeah, I think the huge wheels just look wrong on these cars.
Old Mar 15, 2010 | 11:05 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
I like it it's different, i would say a 2" drop you might have to roll the fenders just in case of rubbing, but with that small tire profile leaving a gap won't look good at all. I understand this might not be everyones style but the car looks good and i can apreciate that. What are you planning on doing for center caps though.
ps. the amount of drop will also considerably affect your ride comfort specially with those small tires, it's definetely something to get used to.
Old Mar 15, 2010 | 01:41 PM
Car: 85 z28
Transmission: auto
thanks !!!i like the 20" wheels was just a lil tired of looking at my 18's on the car needed a diferent look...i love your wheels what size tires do you have? and how much did you lower your car?
Old Mar 15, 2010 | 01:46 PM
Car: 85 z28
Transmission: auto
im about to order my springs what 's a good spring to go with i was thinking eibachs what do you guys think...
Old Mar 15, 2010 | 02:49 PM
godreject's Avatar
http://www.ground-control-store.com/...tion.php/II=20
weight jacks, you can adjust your ride height to your personal preference. Pricey but you can always look for a used set, it's worth the price if you plan on switching rim sizes from time to time as well. read this
https://www.thirdgen.org/forums/susp...over-over.html
Old Mar 15, 2010 | 06:17 PM
Twin_Turbo's Avatar
The black one is my buddies, I think he has 255/35s all round but not 100% sure. It's got the Eibach Sport Line kit fr & rear and yellow konis, a 2" drop.
Old Mar 15, 2010 | 06:27 PM
Car: 85 z28
Transmission: auto
thanks!!!!
Old Mar 15, 2010 | 07:07 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
id say get a 1.5" drop rims look sick tho..
Old Mar 15, 2010 | 08:21 PM
Car: 85 z28
Transmission: auto
thanks .and 1.5 is what im looking at..
Old Mar 15, 2010 | 09:04 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Nice color choice.What shade of green is that?
Old Mar 15, 2010 | 09:07 PM
Car: 85 z28
Transmission: auto
thanks !!! i got the color from a scion xb its a stock green looks better in person
Old Mar 15, 2010 | 09:14 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Nice set up Will a GM center cap fit???
Old Mar 15, 2010 | 10:21 PM
Car: 85 z28
Transmission: auto
i need to puchase the caps but the rear will fit the front ones might fit if i use a spacer..
Old Mar 16, 2010 | 02:57 PM
supermariobros's Avatar
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Axle/Gears: 3.73 posi locker ls1 discs
Those wheels look good, and DEFINITELY lower it it will make them fit perfect. Not a fan of 20s but they can look good, just like in your case.
Old Mar 16, 2010 | 07:33 PM
Car: 85 z28
Transmission: auto
thanks bro!!! i like the way they look to..what do you guys think of the k sport lowering springs 1.75 lowering?
Old Mar 19, 2010 | 01:59 AM
88convz's Avatar
Car: 88 Iroc-z28 Convertible.
Engine: TPI 5.7
Transmission: 700R4 w/mild shift kit.
Axle/Gears: Stock.
What engine are your running? Mods? Nice color combo.
Old Mar 19, 2010 | 05:50 AM
third_genbowtie's Avatar
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
what he said
colton_carlson
Mar 8, 2019 12:21 PM
fcorallo
Aug 20, 2015 11:28 PM
kah992
Aug 19, 2015 02:55 PM
Fronzizzle
Aug 9, 2015 01:15 PM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
