Southern California Area Southern California Members.
wiring and emissions
Old May 20, 2010 | 10:16 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Is this the right diriveter valve for my 91 Z/28 350? I noticed in pics that most of those d valves have a perforated box facing the front of the car, but mine doesn't have one.
Also these wires. I think the 3 red wires (2 are connected) go to the starter?
The white connector goes to the knock sensor, The thick purple wire thats cut I have no clue and the last connector that looks a little burned and is patially missing I thought went to the 02 sensor, but I noticed my exhaust manifolds and the hole for the 02 sensor is on the left one. Are my manifolds the right ones for my year Camaro?
I did this thread all over again because I wasnt getting any traffic at the TPI forum
Old May 20, 2010 | 10:19 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: wiring and emissions
put this thread in the general forum...
Old May 20, 2010 | 11:06 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
purple wire looks like the starter wire. the other wire is probably the fan switch wire.
Old May 20, 2010 | 11:14 PM
Car: 1991 red Z/28
I figured that the SoCal forum would be the busiest so thats why I moved it to here.
It took me over an hour to redo it to here as I have a VERY slow computer. LOL IF a moderator wants to move it general engine forum, he can do it quicker than I can Hopefully I'll be getting a new computer sometime later this year
Old May 21, 2010 | 10:49 AM
STEWARDORNG's Avatar
HEY, TRIED TO LOOKING AT THE HARNESS ON OUR CAR AND COULD NOT SEE IT WELL ENOUGH BUT I CAN TELL YOU THE O2 SENSOR IS IN THE DRIVERS SIDE MANIFOLD. YOU MAY WANT TO TRY KRAGENS WEB SITE MY BROTHER INLAW FOUND SOME WIRING DIAGRAMS THERE IF I CAN SEND THEM TO YOU I WILL.
Old May 21, 2010 | 11:19 AM
racethesunlive's Avatar
Car: '92 Camaro
89 TA called it, the grey wire goes to the fan switch on the passanger side of the block between cyl 6 and 8 seen here:
IMAGE_167-1.jpg?t=1274458715
Old May 21, 2010 | 02:40 PM
Car: 1991 red Z/28
Cool, thanks guys. Big help Now to figure out the D valve.
Old May 21, 2010 | 04:03 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
That looks like the right D valve, it just doesn't have the cover on it.
Old May 21, 2010 | 07:32 PM
Car: 1991 red Z/28
Now if I can find a cover LOL
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
69 Six Pack
Oct 5, 2015 07:51 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
