Southern California Area Southern California Members.
ls1 wiring help?
Old Jun 3, 2010 | 07:15 PM
jll87TA's Avatar
Car: 87 trans am, 82 trans am
Axle/Gears: stock
ls1 wiring help?
Hello. Any of you guys know any1 or a shop where I cnt take my 87ta to wired up da ls1 I have some1 to put da da ls1 in my car. All I need is some to do all the wiring. I have the 350tpi and swapn in the ls1. Thanx
Old Jun 3, 2010 | 11:04 PM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
Axle/Gears: 10 bolt/2.73
Re: ls1 wiring help?
Does the LS1 have a harness from the car it was removed from? And is the harness from the old TPI still in the car?
Old Jun 3, 2010 | 11:14 PM
jll87TA's Avatar
Axle/Gears: stock
Yes to both ?s
Old Jun 3, 2010 | 11:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you have a 350 TPI why would you want to spend the money and hassle to change to an LS1? I can see upgrading a carb or a TBI to LS1, but you already have the high performance 350 TPI.
Anyway, try Cunningham Motorsports: http://www.cunningham-motorsports.com/
Old Jun 4, 2010 | 03:23 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
https://www.thirdgen.org/forums/ltx-lsx/
Old Jun 4, 2010 | 03:27 AM
third_genbowtie's Avatar
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
sun of a bi@%h he makes a good point..you know if my car came with tpi i dont think i would of ever done the swap. i seen alot of good #'s come out those engines. but just for thought, would you get better mpg with the ls swap? or would it be the same??
Old Jun 4, 2010 | 08:54 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
FYI per wikipedia
Years: 1985-1992
The new 1985 L98 added tuned-port fuel injection "TPI", which produced 230 hp (172 kW) and 330 lb·ft (447 N·m). It was standard on all 1985-1991 Corvettes (rated at 230 hp (172 kW)-250 hp (186 kW) and 330 lb·ft (447 N·m)-350 lb·ft (475 N·m)). Aluminum cylinder heads (Corvette only) were released part way through the 1986 model run and continued through the end of L98 Corvette production in 1992. Optional on 87-92 Chevrolet Camaro & Pontiac Firebird models (rated at 225 hp (168 kW)-245 hp (183 kW) and 330 lb·ft (447 N·m)-345 lb·ft (468 N·m)) 1987 versions had 10 hp (7 kW) and 15 lb·ft (20 N·m) more thanks to 9.5:1 compression and a change to hydraulic roller camshaft. Compression was up again in 1991 to 10:1 but output stayed the same.
LS1
The LS1 was rated at 350 hp (260 kW) and 365 lb·ft (495 N·m) since 2001 (LS6 Intake), 1997-2000 350 lb·ft (470 N·m) in North America, depending on the application.http://www.gmperformanceparts.com/Pa...l.jsp?engine=2 The LS1 was used in the Corvette from 97-04. It was also used in GM F-Body cars with a rating of 305HP - 315HP. In Australia, continuous modifications were made to the LS1 engine throughout its lifetime, reaching 382 bhp (285 kW) in the HSV's YII series, and a Callaway modified version named "C4B" was fitted to HSV GTS models producing 402 bhp (300 kW).
Old Jun 4, 2010 | 09:26 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
Some times I wish I did an LS1 swap but I just think TPI is more fun. More thought is required to make the power with TPI but that's part of the fun.
Sounds like you made up your mind about the LS1 swap just do it right & no hacking.
Old Jun 4, 2010 | 09:50 PM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
My friend Jason has already done this swap. He can pretty much do anything with an F-body, wiring, motor swaps, whatever. He also built the harness for my friends LS1 swapped 2nd gen Camaro.
He is mostly familiar with 4th gens, but has worked on plenty of 3rd gens as well. He is pretty well known on the Western section of the LS1tech forum. Tell him Jeremy referred you. He will come to you and look at the car and setup a game plan. (714)9-ONE-7-SEVEN532
He is busy with a lot of projects sometimes, including his own car, so if he can't do it for you let me know. As a last resort, I can refer you to the shop that built the harness for my LT1 swap.
Old Jun 4, 2010 | 11:43 PM
jll87TA's Avatar
Axle/Gears: stock
i think the ls1 has more mpg, the ls1 would have alot more power than the l98. thanx "plasma sword" ill definitely give him a call.
Old Jun 5, 2010 | 01:56 AM
Kevin91Z's Avatar
Yes the LS1 has reported MPG in the range of 25-30 while stock and slightly modified. If our SBC's could use street heads that were 18* instead of 23* then yes we would have better MPG and power, too. I'm not denying that LS1's are better than TPI's. I'm saying its my opinion that swapping a 350 TPI to a 350 LS1 is not something I would recommend, due to the cost, and hassle.
Old Jun 5, 2010 | 03:17 AM
thegooseman's Avatar
Car: 1992 RS
SRJ?
Old Jun 5, 2010 | 09:37 PM
Z28FAST1's Avatar
Mod for mod you get more power, better MPG, broader powerband, and it's easy to work on and diagnose. You can send your harness in to get converted to a stand alone set up for about $300-450, then all you have to do is hook up 5-6 wires and your done. google lt1 wiring
Some members think you will "bastardize" your car if you take out the L98 but ironically the fastest TPI cars in so cal are running 4th gen transmission, rear ends, brakes, etc. lol
I have a thread in the LSX swap forum w/more details.
Old Jun 7, 2010 | 12:50 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
South Gate Dyno a block east of Firestone & Atlantic, the do lsx swaps in gm vehicles.
Old Jun 7, 2010 | 02:05 AM
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
I see you haven't let go of the "Bastardize" comment. It's still funny when I think of when it was brought up...
Adrian
Old Jun 7, 2010 | 02:28 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
im proud of building my daily driven 3rd gen/ 4th gen bastardized which never gives me any problems . mpg is great. drive ability/reliability is great. and hwy runs are fun. im 21 and its hard to stay off the pedal but i have so much more plans for it.. ive just begun..
wiring was fun btw. its pretty cool when you attempt it your self because if you ever run into the problems you're a step closer to finding the issue.
Old Jun 7, 2010 | 02:41 AM
Z28FAST1's Avatar
Adrian
It's all in good fun, I'm sure everyone knows why I'm biased. Tell you what though after LA Invasion and seeing what a certain grey TA can do, i have a new level of respect for the TPI engines.
Back on topic, the company that did my harness made it very easy to wire up and also reprogrammed my computer to bypass VATS and other features that don't carry over from the 4th gen.
Old Jun 7, 2010 | 12:54 PM
jll87TA's Avatar
Axle/Gears: stock
Is this place by the rail road tracks? Because its close or where exactly is it?
Old Jun 7, 2010 | 07:12 PM
godreject's Avatar
Exactly right off the railroad tracks, i forget the guys name but they were real cool.
As far as Tpi is concerned im Sticking with TPI, i feel it fits my engine bay better. Besides i can do minor upgrades as my wallet allows, an lsx swap is throwing a chunk of money all at once to get it going and what you end up getting is a stock ls1 motor combo. When the time comes for an ls1 i'm sure i'l just pick up an 01-02 SS
Old Jun 7, 2010 | 10:47 PM
jll87TA's Avatar
Axle/Gears: stock
i passed by there today, i saw the place rigth off the railroad tracks and it seem like they went out of business or moved location.
Old Jun 8, 2010 | 01:45 AM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
Originally Posted by thegooseman
SRJ?
Right.
Old Jun 9, 2010 | 01:30 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
if you find the deal its well worth it.. just research.
a lot of people think ive spent so much money because of the appearance of my car.. but in reality the only receipts ive had for performance parts arent really performance parts a factory clutch, a used intake, a walbro fuel pump, mufflers and labor for a temporary y pipe and a tune.
if you have the skills, knowledge and availability its a good opportunity to do something you want.
ls1's look good in almost anything its just a new idea
Old Jun 12, 2010 | 01:16 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
The performance and tuning potential of any LSx engine will FAR excede the potential of a TPI engine, hands down. Flash computer technology, ease of making HP, and head design are centuries above the old TPI's. They are both great engines, but they are not even in the same ball game IMO. You throw a chunk of money up front, but your car goes from a 14 second car to a high 12 second car with a bone stock LS1. Bolt ons will get you mid to possibly even low 12's. HUGE difference.
Old Dec 3, 2021 | 03:56 PM
walkingdead5's Avatar
Car: 1991 Camaro Z-28
Last edited by walkingdead5; Dec 3, 2021 at 03:59 PM. Reason: posted on wrong thread
Old Dec 28, 2021 | 10:34 AM
o
iroc stangs
Sep 5, 2009 11:50 AM
817bigtex
Jul 8, 2008 12:48 AM
91_5.7_TPI
Dec 12, 2007 04:46 PM
