Battery relocation, is it legal?
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Is it in our communist state? Will the tech care?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Battery relocation, is it legal?
Not sure if it's legal or not but, for safety sake, you should install an external cutoff switch in the rear.
But now that I think about it, some cars have them under the seat.
Probably isolated tho.
Thanks, Don. I just thought about this; I guess when It comes time to smog it I could just install the battery back to its original spot. The cutoff switch is a good idea, I hadn't thought about it. Thanks.
Car: 87 GTA
You'll want to use a dry cell (Optima-type) if you put it in the interior. No more battery acid or a chance of outgassing.
Or use a Battery Box if you put in a standard, acid-filled battery.
Car: 92 T/A Convertible
Engine: 5.7 (L98)
Transmission: WC T-5
Axle/Gears: 3.27 LSD
