failed smog thread.....
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: failed smog thread.....
Notice your NOX is low and HC high, that usually means the 02 might not be working, or a bad injector, check them with an ohm meter, should be 12-18 ohms.
When the NOX is low, that indicates cool combustion ie. rich mixture.
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
i have brand new injectors bosch III old ones were ohming low...maybe it killed my o2?
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
well when i failed emissions on my car everything failed. So what i did was i bought some techron fuel injector cleaner and filled my tank then poured it in and ran it for about 100 miles then i bumped my idle up to about 900 and the day i was scheduled to take the sniffer test i drove it on the freeway for about a half hour till it got nice and warm and then went right to the testing station and had them pull it in without shutting off the car. Since i did that it passed with flying colors also check your plugs and timing
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Which of your cars is that so I can add it to my chart.
make, model, year, engine, year, trans,
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
That was my issue as well.I retarded the timing a couple (maybe more) degrees & raised the idle speed a couple hundred too.Plus the unsual, inpect/clean plugs,check/replace cap & rotor.I also poured a bottle of that Lucas fuel/octane booster thing.
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
theyre 22lb injectors the car has a 350 but is tested as 90 irocz 305 700r4
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
oh and i picked up the totalled 02 ss today will post pics tomorrow
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Could having the fan running with key on have had hurt my #s? I go for a retest tomorrow................
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
My car likes to run about 140-160 around town.So i took the air dam off to spike the temp into the 200-210 range.
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
swapped wires, cap, rotor, coil, plugs, and 02 sensor still didnt pass. ended up paying under the table, no lube.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I know the feeling.Least now you dont have to worry about the registration while doing the swap.
