got my third gen started
Car: 86 iroc,89iroc,98z28
Engine: 305,305,ls1
Transmission: 700r4/4l60e
Axle/Gears: 2.77/3.23
Re: got my third gen started
that's great you guys sound so freaking happy I would be too ... looks killer
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
nice.. !!! post some pics of the exhaust when your done. im looking into a dual set up.
Car: 86 camaro z28
Engine: lq9 6.0
Transmission: 4l60e
Axle/Gears: 342
i will bro ur car came out clean. im not going to run duals anymore. im going to go single all the way back into dual. im going to get a custom 3 in y pipe. 3in piping all the way back over the axle. into a magnaflow muffler. then i going to run daul 3in wide 18in long stanless tube with an angle cut. i talk to the guy and he said it pontless to run dual becuz it going to scrap everywhere. on there no space on a third gen to fit it nice and tight. but if u do that good luck on it bro
Car: 86 camaro z28
Engine: lq9 6.0
Transmission: 4l60e
Axle/Gears: 342
Car: 1992 RS
Cool...I remember seeing a car at Johny's shop(transmission shop) with a cali generalz decal on it. Looked similar to yours.
What are you doing for the gauges? Did you get a converter box, fourthgen cluster, or did you go fourthgen dash all the way?
Car: 86 camaro z28
Engine: lq9 6.0
Transmission: 4l60e
Axle/Gears: 342
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Thats alot better than swapping the dash.4th gen dashboard is butt ugly, so is the console.Very nice.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
my tranny k member hits before it ever hits my exhaust. but yet again im running a wack 2 1/4 piping up front into a y merge back to a 3 inch..
Car: 86 camaro z28
Engine: lq9 6.0
Transmission: 4l60e
Axle/Gears: 342
Car: 86 camaro z28
Engine: lq9 6.0
Transmission: 4l60e
Axle/Gears: 342
ooh ok . is your car lowered? im sure you can get away from scraping while using the 2.5 duals. guess it depends on the skill/experience of the welder.
just finished my exhaust havent seen it but my friend pick up my car from the shop while i was i work and he said it look sick as hell. will post up pics soon
Car: 86 camaro z28
Engine: lq9 6.0
Transmission: 4l60e
Axle/Gears: 342
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"Get it dialed in and bring it to LA Invasion so that we can whoop some TPIs"
That should be no problem. The question is how bad will you whip the TPI's.
FYI, you can use the "Quote" or multi-quote button instead of copying and pasting previous posts
Car: 86 camaro z28
Engine: lq9 6.0
Transmission: 4l60e
Axle/Gears: 342
[quote=Z28FAST1;4859776]When are you guys doing this event? post up the link, I'll be interested in checking it out.
join are web site it one of the topics. should be fun. anyone is welcome
www.caligeneralzcc.com
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
