Southern California Area Southern California Members.
starting problems need advice
Old May 15, 2011 | 11:27 PM
LBRS's Avatar
Car: 89 camaro RS, 90 camaro
Engine: 355 TPI, 305
Transmission: 700R4, 700R4
hey everyone
Ive been having issues getting the car to start and wanted to get sum input on u guys might think it may be. Now the car dont start but it cranks was thinking it could be my ignition coil but Im getting spark there, just checked my ignition control module and it tested fine, my injectors are pumping fuel into the throttle body so thats a good sign, my fuel pump clicks n makes noise for over 2 sec so looks like thats fine, put in a new fuel filter. I was told to get some starting fluid n spray it into the throttle body and it started but it dies within 3 sec unless I keep spraying the starting fluid. If any of u guys might have an idea of what could be going wrong post up need to get it running again.
Thanks for taking the time to read my post
Tony
Old May 15, 2011 | 11:35 PM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
Re: starting problems need advice
check the starter and the starter solenoid
Old May 15, 2011 | 11:42 PM
LBRS's Avatar
alright u think that also can be a problem even though the car cranks. I'll check that out ASAP
Old May 15, 2011 | 11:48 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
not at all, the problem seems to be fuel related.
Old May 15, 2011 | 11:59 PM
Engine: 5.0 305 TPI
that is true too but it could also be a timing issue!!!!!
Old May 16, 2011 | 12:04 AM
LBRS's Avatar
I was thinking it could be fuel related as well just kinda stuck on what it could be tho. I kinda think it could be my fuel pump but it clicks and u can hear it turn on so idk if it is also I checked the fuel pump relay n made no difference
Old May 16, 2011 | 12:10 AM
LBRS's Avatar
Im kinda sure it cant be a timing issue since I havent messed with the timing at all
Old May 16, 2011 | 01:07 AM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
just because it primes doesn't always mean it has good pressure. Search the tbi forums to see what you should have
Old May 16, 2011 | 02:10 AM
rock861261's Avatar
does your security light blink? are you using a coded key?
Old May 16, 2011 | 04:47 AM
oramac91's Avatar
ya its all fuel. your pumps not working right.most time a loud pump is a bad one. if u can start with starting fuild, its the pump or computer or masair senser or oxergn senser, buy a computer checker that reads problems. cost about 30 dollors.best 30 buck you ll ever buy. gl
Old May 16, 2011 | 07:28 PM
LBRS's Avatar
my key has a chip on it since I have VATS... and no my security light dont blink
alright thanks bro
well I hear it clicking when i turn my key for 3 sec i can hear the pump click
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
jbd1969
Aug 17, 2015 07:06 PM
92camaroJoe
Aug 13, 2015 06:07 AM
