Anyone seen L98 aluminum heads in the junkyard
1 Post
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
im trying to buy dirt cheap L98 aluminum heads from the junkyard so if you seen a pair let me know or if you have a pair for dirt cheap let me know..they will be going on my '89 350 tpi engine
1 Post
Re: Anyone seen L98 aluminum heads in the junkyard
that is true but i had sent some member here a messege on a thread called junkyard scores and he said he found a vette but was on a special side in the junkyard and said it had the aluminum heads but had vette tax he stays in riverside if he can spot that maybe there is a chance one could be in some junkyard in so cal
1 Post
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I've looked at second hand Aluminium heads and it's just not worth it.
$500 for second hand heads and at least $500 to recondition them
You can buy brand new aluminium Pro Comp heads on eBay for less than $700 and they have better specs.
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
yeah good luck trying to find an L98 Corvette at the junk yards.. in 15yrs ive seen 1 but the engine was already taken... because its a "vette" motor
1 Post
there has to be at least one in the junkyard
1 Post
Car: 1990 GTA
Engine: 5.7 V8
i have been going to the junkyards for awhile now and 3rd gen parts are getting more and more scarce. but with saying that you might get lucky it could happen.
Anyways i will keep an eye out for you when i go
best of luck to you
tom
best of luck to you
tom
Guest
Posts: n/a
I think the best budget head is the afr stage one head for 1,300 as I had mentioned in another thread. Im running the built ported Vortec head and I made some serious amount of torque to the rear wheels. Im guessing the Afr stage 1 head would probably increase my hp. Just a little more flow.
1 Post
Car: 1990 GTA
Engine: 5.7 V8
1 Post
That might be true but I don't have the $1,000+ for heads that is why im looking for junkyard ones unless someone has the aluminum vette heads they want to sell me for dirt cheap
1 Post
Yeah they are scares the tpi firebird is more scares than the camaro, yeah hit me up wen see one
If you dont have the $400 for the Corvette heads, then you probably dont have the money for the aftermarket intake you need to make those heads fit on your engine, either. The Corvette heads have a different intake bolt angle that will not work with a Camaro/Firebird TPI intake. Also the Corvette heads do not have the EGR passages as well. So you'll need to hook up an external EGR system like the Corvettes to make it pass the emissions test.
If you're as poor as you say you are, then your money is better spent on preventative maintanance, so the car doesnt leave you stranded on the side of the road and really cost you a ton of money.
Yes I'm harsh, but that's reality.
1 Post
Lets do a reality check here. If you own something that is worth $400, are you going to sell it to someone for $100 because they're dirt poor and begging you for it? I dont think you will.
1 Post
what are the numbers on the corvette heads to look for and for instance if there are about 2 or 3 sets on a table i know only the driver side head has the casting numbers what if they were mixed up and you grab an earlier head with the 113 head would there be a problem how would you be able to grab the same heads
