My Engine Is Out
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
My Engine Is Out
It's possible that a rod bearing went bad. I'll find out tomorrow. Oh by the way, who said you can't pull the engine out without having to take off the hood, headers, fans and radiator. I move the charged A/C compressor to the side and held it by a strap.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: My Engine Is Out
Nice job, saved a lot of time by leaving everything else in place. One must be a little careful is all.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Don't forget the rent-a-motor fee.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
Ah, you lads decide to test that theory make sure to let me know... Something tells me the footage I'd get would be YouTube worthy
Car: 1990 RS
Engine: LO3 TPI
I found the problem. It's a rod bearing and it killed the crank.
Yep! It's time for a stroker.
I have a 280XFI Cam for sell, $150.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Car: Z/28
Engine: 355
Transmission: Turbo 400
All you need now is a set of AFR 210 cylinder heads and a carburator! Oops scratch that last word. Then "IF" you hook it up at the track, you can add a 12 bolt rear.
Car: 1989 iroc convertible
Engine: 305 tpi
Transmission: 700 r4
lol either u guy got a better job than i do ( and i do well for myself) or u are single and no kids . Mine biotches when i spend 3 hrs and 1k on my ride tell me ya how ya do it ? by the way nice looking ride.
I have a wife and a 16 year old kid an Im 46 years old. I have a good job with benefits.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Car: 1988 Pontiac trans am
cant wait for this to be put together . Short runner vs. big long runner . i wanna see what your setup will put down . Ever since you mentioned skipping the 355 and going for a 396 i cant stop reading about them .
Right now its on hold. Got to smog the car first. Just replace the cats. The speedometer stop working. Have to pull the tranny to fix it. The drive gear broke. Just got another one in the mail today. Finally going to change out the bent axles next week and taking out the 3.73's and going to install 3.42's. It will probably be done around April or May for sure. I have to get a few more parts before it goes to the machine shop.
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
what symptom made you think of a rod bearing?
i must say..thats one clean engine bay
Car: 1989 GTA
Engine: 369 TPI
So for a couple of reasons I am out of the porting business including it being a big pain in the ****.
Car: 1992 RS
There is not to much to a miniram. Should be a cake walk porting compared to a TPI setup. ;-)
Car: Iroc-Z
Engine: 383ci
Transmission: 700hp 700r4
Axle/Gears: 3:45
This is probably maybe what Vincent had machine work for that Tpis cam. I would just go with a custom Engle or Cam motion cam small base circle. So there is more than one way. I just learned this a month ago from Gene.
There is progress now. I just dropped off my engine block today. Since it spun a rod bearing on #8 cylinder, it kinda scored the cylinder wall. They are going to try to hone it a little. If it doesn't work, he may have to bore it out to .060 meaning I will have a 388cu. It already .040 over. Oh what fun this will be.
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Come on Vincent get that motor together! I keep it fair I get seven plus months to finish mine like you have. Just dont blow a rod before then. I hope your not wasting a chance with that 388 that just isnt going to be right at .60 over if it's needed. Buy a block Vincent .30!!!! Vortec 4 bolt main. Dont for get your Total seal rings! And put your Vette Sr back on that Mini Ram sucks.
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
What you went with a 3.75 over the 3.875 396 I must have missed that. Ya I understand why. Well sounds like all your hope is in the ZZX cam. That's to bad.. My choice is the 219/219 Lingenfelter. And you know who ran that cam already. Im going with Eagle over the Scat's stuff. Well hope this engine works out for you. You should have done this 8 years ago. Nothing like something new in your ride.
Car: 1989 GTA
Engine: 369 TPI
Good. Get that thing together and get out to Fontana and set some new club records. I feel sorry for your T5 transmission.
I did but didn't have the money for it. Plus I still wanted to use my old block. I went .060 because the number 8 cylinder was scared up and the bores was already .040. So why not take it to the limit. This was about $1000 cheaper
Not yet but will start back on it soon. I've been working on my other Camaro.
https://www.thirdgen.org/forums/tech...ml#post5773232
Bring this post back. Got the car running.
I wonder if it will handle 250 shot.
