Southern California Area Southern California Members.
manual to auto swap
Old Jul 3, 2013 | 05:25 PM
jrmartino78's Avatar
Car: 88 Firebird Formula
Engine: 350 TBI
manual to auto swap
Has anyone done it? Just had mine done in my 88 firebird and I guess there's a hole in the floor that needs to be covered now. The guy also said he had to "strap down" the shifter because there was no where to mount it. Does this sound normal to you guys? Anyone have any ideas for the floor and mounting?
Old Jul 4, 2013 | 07:38 PM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
Axle/Gears: 10 bolt/2.73
Re: manual to auto swap
Yes that's all correct. As far as the whole strap down thing, im sure there was probably a better way to secure the shifter...
Old Jul 4, 2013 | 09:59 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You'll need the bracket thats welded to the auto tunnel to bolt down the shifter.Plus weld the hole left from the manual shifter.
Old Jul 5, 2013 | 07:16 PM
Engine: 350 TBI
Does anyone have any suggestions on where I could get this done?
Old Jul 5, 2013 | 07:19 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I would get an B&M shifter that has all it's stuff included and call it a day.
Old Jul 5, 2013 | 07:43 PM
Engine: 350 TBI
Shifter isn't my problem tho. I went from a manual to auto and I need to cover the hole where the manual shifter went through.
Old Jul 5, 2013 | 08:30 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Cut out the tunnel off a car at the junkyard...portable sawzall or even a cordless drill are your friend
Old Jul 6, 2013 | 07:52 PM
Parrydise7's Avatar
Dyno Don converted my '85 from a carb'd automatic to a fuel injected stick. Not a job for amateurs. Give Don a call and talk to him about it just so you know what you are getting yourself into.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
