Feeler Thread-drivetrain part out.
Car: 68,87,99 maros, 07 tbss
Engine: TPI,LS2,LSA,L92
Transmission: T56,T56,T56, 4L80E
Axle/Gears: 12bolts and 14 bolt lol
All parts are spoken for. Boosted LSX here I come
Re: Feeler Thread-drivetrain part out.
Deposit received on engine. Trans setup only thing left for sale. Asking $2500 for everything. Trans, clutch, bell housing, flywheel, hydraulics, driveshaft, shifter.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It has the small shifter base so you don't have the cut the floor.
It does require a 2" shorter torque arm though which I'm sure is not included.
Not in a rush to sell. I might just keep it. Sounds like it's a MN12 from factory. They addapted the midplate to an LS style midplate. So just removing the adapter plate and installing LS bellhousing and hydraulics I'll be
Golden.
Uh...no the input shaft is longer to make up for the adapter.
The T-5 bellhousing is about 7" deep + the adapter, the LS and the LT are only about 6" deep.
I put an LS trans with the adapter in a third gen and it didn't reach, I had to use a special pilot bearing. (longer)
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Here's the video of the car on the Dyno with the latest combo.
Bump... Still have the trans FS. $2500 obo for the trans, clutch, bellhousing, driveshaft, hydraulics, shifter. Open to trades for an LS1 T56 plus cash
Car: 1988 Pontiac trans am
that day was fun, I remember Don chocking his own neck when asked what he thought about OP's GMMG muffler, hahahaha
LT1Formula
20
Nov 14, 2015 12:02 AM
