Sponsored Vendors Connect with our Sponsored Vendors that sell the parts you need for your Third Gen Camaro or Firebird. Show your support for our vendors by offering feedback and telling friends about their services.
UMI Performance 3rd Generation K-member Now Available!
Old Nov 25, 2011 | 10:09 AM
UMI Performance's Avatar
1982-1992 F-Body K-member for TPI, SBC, BBC and LSX Engines
UMI Performance is proud to announce the design of our 82-92 K-member is complete and we are adding the finishing touches now. The K-member will save 20 lbs of front end weight while freeing room for turbo set ups, headers and other exhaust items. The K-member that will actually ship will have some small changes compared to what the picture shows, the rear control arm mount is now boxed and there is a forth motor mount hole. The finished design will be rock solid.
Currently we offering four K-member options, two for the standard SBC/BBC/TPI and two for the LSX engines. I will explain each one below.
#2401- 1982-1992 GM F-Body Tubular K-member, Coil Springs
This item will work with TPI, SBC and BBC. It features bolt in spring perches for standard springs and lowering springs. The K-member will except factory motor mounts or solid mounts like UMI P/N 0051.
#2402- 1982-1992 GM F-Body Tubular K-member, Coil Over
This item will work with TPI, SBC and BBC. This item is designed to work with coil over set ups only. The spring perch bolted to the K-member in the picture will be replaced with a support brace. The spring perches can be purchased at a later date if needed to convert to factory style springs. The K-member will except factory motor mounts or solid mounts like UMI P/N 0051.
#2403- 1982-1992 GM F-Body Tubular K-member, LSX Engines, Factory Springs
This item is designed to mount a LSX engine into your 82-92 F-Body. It features bolt in spring perches for standard springs and lowering springs. The motor mounts in the picture are similar to what we will supply but not the actual mounts, they weren't completed in time for pictures. You will need factory LSX rubber motor mounts or UMI P/N 2323, solid motor mounts.
#2404- 1982-1992 GM F-Body Tubular K-member for LSX Engines, Coil Overs
This item is designed to mount a LSX engine into your 82-92 F-Body. This item is designed to work with coil over set ups only. The spring perch bolted to the K-member in the picture will be replaced with a support brace. he motor mounts in the picture are similar to what we will supply but not the actual mounts, they weren't completed in time for pictures. You will need factory LSX rubber motor mounts or UMI P/N 2323, solid motor mounts.
We are asking for 3-4 weeks to ship this time. We will do our best to have these available as fast as possible.
Thanks for looking!
Old Dec 28, 2011 | 04:53 PM
blakecharles's Avatar
Re: UMI Performance 3rd Generation K-member Now Available!
OMG that looks nice!!! When do you expect to have these in stock? or will they always be made to order??
Old Dec 28, 2011 | 10:30 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
**** that's a good deal....
Old Dec 29, 2011 | 09:24 AM
Once the design is completed and production starts they will be a product we make everyday and usually in stock. If one isn't in stock shipping time will be around 2 days. Right now this is first production run and this is why ship times are long.
Thanks for asking!
Ryan
Old Dec 29, 2011 | 10:29 AM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
can you do standard black powdercoat?
Old Dec 29, 2011 | 10:42 AM
All UMI items are available in red or black at no additional charge.
I hope that helps!
Ryan
Old Dec 29, 2011 | 01:24 PM
You have any pix with the a arms too????
my antennas are up on this one!
Old Dec 29, 2011 | 01:35 PM
Project-RS's Avatar
heres from there site. just click on the pic.....
http://www.umiperformance.com/catalo...roducts_id=627
Old Dec 30, 2011 | 09:59 AM
Thank you sir.
You can also find just the a-arms here- www.umiperformance.com/2031
Old Jan 4, 2012 | 11:43 AM
Project-RS's Avatar
any updates on the k member?
Old Jan 4, 2012 | 12:21 PM
bump... yea, I wanna know too.
got the 1st production out yet? or will I have to wait 3 weeks after my order?
Old Jan 4, 2012 | 12:25 PM
Project-RS's Avatar
from a recent post, umi said there working out a few kinks. i ordered mine the 6th of last month and there still working on them.
Old Jan 4, 2012 | 05:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im sure it will be a little while before they are out. I would rather wait a bit and receive a part that fits properly, than get one that was tossed out the door without any real fitment testing and have issues.
besides is cold as hell here and i dont want to be in the garage messing around right now
Old Jan 4, 2012 | 05:57 PM
Project-RS's Avatar
i know what you mean. it was 9 degrees here today
Old Jan 4, 2012 | 06:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
global warming
Old Jan 6, 2012 | 11:04 AM
I need a k member to finish my swap. If I cannot get one soon, I'm just going to use stock (don't want to tho).
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
