problems with rearend swap
Old Apr 21, 2002 | 07:15 PM
camaro6spd's Avatar
Ok, i went from a 10 bolt, drum, worn posi to my 9 bolt, 3.45, working posi disc. Well i have just a few problems....first the e-brake does not work too good...it works some but with the car in drive it still can turn the wheels up in the air, the rear brakes(hydralic) do not work that good either, but i still have the drum PV in there. I am gonna switch that out and get that GM recall caliper rebuild kit for them, then have STS bleed the breaks. Also I need pictutes of how the sway bar mounts up on a 9 bolt....it is different then the 10 bolt.
Old Apr 22, 2002 | 07:07 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I swapped the rear sway bar (and rear end) from a 87 GTA with a 9-bolt disc into a 82 Z28
(originally a 10-bolt w/drums) without any problems at all. It does appear to hang down slightly more than before at the pumpkin, but not much.
Old Apr 23, 2002 | 09:49 AM
camaro6spd's Avatar
ummm, the only problem is that mine was rigged.....i am gonna go see where i can get the mounting hardware for the 9 bolt, ne one have ne other ideas besides the GM dealer.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
