Springs
Old May 2, 2002 | 04:33 PM
Havoc's Avatar
Springs
I currently have an 82 Camaro Z28 the passenger side tire has Gouges in the side wall I asume from bottoming out .It has ruined two sets of tires.What springs could I use to stiffen up the rear.Why only one side is possible the spring is completely shot on that side.Is it possible It's shocks I changed over to KYB GR 2"s a couple years ago.Any suggestions.Would really like to put on a set of drag radials but not if the side is going to be all eaten up. PLEASE Help.
Old May 2, 2002 | 05:55 PM
Havoc's Avatar
Heres a picture of what I'm talking about.
Old May 2, 2002 | 06:18 PM
pianiy's Avatar
You could modify your bump stops and make them larger say an inch or two... you'll be losing travel and you'll bottom out more, but you'll save the tires. Stiffer springs would help, but the shocks really just dampen the springs, they don't do as much as the springs do.
Old May 4, 2002 | 12:00 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Looks like your springs are completely shot. Have a look at them to see if they have snapped a coil off or something obvious like that. I suggest you buy a new set of springs. If you need the part number for them, search the boards for it.
Old May 4, 2002 | 12:17 PM
War_Eagle's Avatar
Check with some of the shock manufacturers, there are some stiffer springs out there. good luck.
By the way are those wheels Torq-Thrust II's ? what size?
Old May 4, 2002 | 12:24 PM
Havoc's Avatar
Yes They are TT2's 17 on back 16 on front.
Old May 4, 2002 | 12:26 PM
Havoc's Avatar
Are WS6 springs pretty stiff or what about eibach.
Old May 4, 2002 | 10:18 PM
transam84's Avatar
I'm not sure if you want used springs but I have a set of front springs off my 84 Trans Am. they are pretty stiff. I swapped all my stuff out for ws6 but it turns out that the springs that were in my car were they same I just put in. sounds dumb I know but if you want the pair cheap you can have them for $10.00 plus shipping from Kasson Minnesota 55944. not sure how much they weigh. Mike
Old May 4, 2002 | 10:22 PM
transam84's Avatar
I just had to go weigh the springs. they weigh 11 lbs each unpacked. maybe another pound or two after packing
Old May 5, 2002 | 12:55 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
In addition to the springs I'd also check the alignment of the rear end. Sounds like you might need an adjustable panhard bar.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
