Dat's da Brakes!!
Old May 15, 2002 | 08:43 AM
Hung Start67's Avatar
Dat's da Brakes!!
Guys got a brake question...just picked up this 92 z-28 with 45,000 miles on it...well the brakes are to say the least not very responsive..i mean they will stop the car but you really have to put your foot into it..its not a soft pedal...and it does not go all the way to the floor...could it be that the brake fluid is just plain wornout? the color of the fluid looks like hersheys chocolate milk..lol...maybe the power booster or master cylinder?..not sure...any suggestions would be appreciated...thanks guys.
Old May 15, 2002 | 09:08 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Hershey's chocolate milk? Ewww... reminds me of a car I did that the brake fluid had the color and consistancy of 10,000 mile motor oil...
I'd flush the hell out of the system before doing anything else. Empty most of the master cylinder with a turkey baster or something similar and replace with fresh fluid, then bleed 'till you get clean stuff at each wheel...
Old May 15, 2002 | 10:03 AM
Beefy89's Avatar
Might want to rebuild or replace the calipers also if the fluid is that bad..You can get new calipers at Autozone for $9.99..
Old May 15, 2002 | 03:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
...and if you're buying new calipers, ya might as well go all the way and replace the brake hoses now. They deteriorate internally, and clog up, and then the car yanks to the side when you hit the brakes. Wouldn't it suck to replace the calipers (and un-do the brake hose), and then wind up having to replace the front brake hoses a month later?? (Replace both at the same time, they're about $25 each).
If you want a snazzy tool that's worth every penny, check out http://www.brakebleeder.com - I bought the V12 (w/smart pak) when I was working on my rear discs, I wish I had it earlier. Bleeding is easy as hell now, and, I -know- there's no air being introduced anywhere.
Old May 15, 2002 | 08:41 PM
Hulk0202's Avatar
Whatch gonna do when the sun dont shine....
Old May 20, 2002 | 02:08 PM
EuG's Avatar
EuG
Really, that cheap huh?
I think it wouldn’t hurt to replace mine as well…
Old May 20, 2002 | 02:09 PM
EuG's Avatar
EuG
P.S. Do you know how much is Master cylinder and brake hoses as well?
Old May 21, 2002 | 08:46 AM
99Hawk120's Avatar
The hoses are $10-$15 each IIRC. The master cyl is like $50-$70.
Old May 21, 2002 | 04:35 PM
Wow i have brakes again...lol
Hey fellas just lettin ya know...drained,flushed and serviced brake system with valvoline syn-power fluid..dot3-4...brakes work much much better.. more than likely gonna do it again before i head to florida with the car....thanks guys..later
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
