Stainless steel brake kit
Old May 16, 2002 | 07:42 PM
Buck268's Avatar
I was looking around, and i found a brake kit - http://www.stainlesssteelbrakes.com/...4ShortStop.pdf
and iw as wondering if it would be worth the money, as my stock brakes are killing me 2 fold, and I do not have the cahs fer an all out 1LE upgrade...
EDIT: here is another link http://www.stainlesssteelbrakes.com/...&carYear=82-92
I was thinking the "Short Stop Kit" for stock (non 1LE) type brakes - anyone have any thoughts?? Would it be worth $300?? Thats about half (maybe less) than what it would cost me fer a 1LE conversion, from what I have read....
Old May 19, 2002 | 08:18 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
All this "short stop" kit gives you is new rotors and pads...that's it. Not much of an uprade in my opinion. If you replaced your calipers and installed braided hoses, I suppose it would be a decent improvement. My RS has standard brakes and it stops VERY well, much better than my Iroc did. FYI, my 1LE upgrade will only run me about $600, not too much higher than that $270 short stop kit if you add in new calipers and braided hoses.
Old May 19, 2002 | 09:32 PM
Buck268's Avatar
Thats true. 600 bucks, you say - are you pieceing it together? I really dont have the time to do that. Plus, if it doesnt go smoothly after I got all the parts, and go to install, I am out a car (its my daily driver...). Basically, if I do the 1LE upgrade, I'll need a very complete kit - including hoses, master cylinder, and spindles! As I do not have time to hunt fer parts enroute to the finsihed product, and I cannot afford to keep my car off the road more than a day or 2 tops. I have heard about Sphoon doing a grup purchase 1LE upgrade type of thing, but the last I heard it was to arrive early in May, and this is kinda...past that...
Anyways, I am not in a hurry to upgrade, but it is something I want to do eventually...
Old May 19, 2002 | 10:24 PM
ebmiller88's Avatar
Yeah, the Spohn deal is taking a while, but that's about the only complete option out there right now except for that $1200 package that SSBC has. Plus, they charge you a core for your spindles, I think it's around $150.
Yes I have pieced mine together. I'm thankful this isn't a daily driver and that helps a lot. I haven't even torn into the brakes yet. I got my parts from a number of places: eBay, personal sales, and new GM stuff. If you want to start getting things together, here's a link that will list everything you need:
http://www.ws6transam.org/1LEbrake.html
No parts hunting on your part!!! Dan's done a lot of research on it and has it nailed down, Also, you can contact AndyZ28 for his expertise on the swap. He knows all about it, too.
You can save money here and there, modify your own spindles, rubber hoses instead of braided, etc. Just look around to find deals. If you need the car but still want to upgrade to 1LE, just repair the car with stock parts and put the 1LE system together, then do the swap when you're ready. Shouldn't take you a weekend to do.....if it all goes smoothly..
Old May 20, 2002 | 10:29 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
SSBC does not charge a core charge for the spindles. Baer does, though.
I added the racing lug bolts.
Old May 20, 2002 | 01:07 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
PF Flyer,
What are racing lugs? Do they come off easier? Do you have any pics of them? What's their funtion? Do they improve anything?
Thanks,
Jesse
Old May 20, 2002 | 03:28 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
I use a standard open ended lug nut on the extra long lug bolts.
The added length makes it easier to put the wheels on and then get a lug nut onto.
Old May 23, 2002 | 01:17 PM
Sergeant's Avatar
How much better is your braking now with the ss system? Drastic or little?
Old May 23, 2002 | 03:00 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
I haven't been to the track yet, but ...
... the testing I've done on the street have been quite an improvement.
I hope to hit the track with Hawk'blues' around the middle of next month.
Old May 24, 2002 | 11:23 PM
AFrikinGoodTime's Avatar
PF, where did you get the studs, or should I ask, are the metric?
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
