Put on new tires and wheels, now car pulls?
Old May 23, 2002 | 06:41 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I just recently swapped wheels and tires from 215/65/15 to 255/60/16. Before the swap the car handled fine. Now, the car will pull, mostly to the right, but sometimes to the left. Or sometimes not at all.
Any ideas?
Old May 23, 2002 | 12:56 PM
82camarov6's Avatar
Check your tire pressure
or maybe it is the road you are on
Old May 23, 2002 | 05:21 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Tire pressure is good.
Old May 24, 2002 | 09:57 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I had a T/A with 15" wheels and then went to my Formula with 16" wheels. The formula can be down right scary with how it loves to follow the road. The wider wheels seem to do this. Your alignment could be slightly off. With the new wheels it could be more noticable now... that would be my guess.
Old May 24, 2002 | 10:07 AM
know_bull88's Avatar
tire pressure is a good bet also check the toe and caster angles. Even though does not have a lot of caster adjustments it may lead you to other problems in you suspension.
Old May 24, 2002 | 11:42 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Yeah I heard wider tires can do that. The tires are used, so I may put some 225 up front. Those will fit on a stock 91 Z28 wheel, right?
Old May 24, 2002 | 05:12 PM
90Form350's Avatar
you may have gotten a bad tire also, i work at Goodyear and we see that quite often. Go back to where u bought the tires (or had them installed) and tell them you're having a problem.
Old May 25, 2002 | 02:34 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Problem there is I bought the tires and wheels used from someone on this site.
Old May 25, 2002 | 03:18 AM
AFrikinGoodTime's Avatar
If the car is lowered you are experiencing bumpsteer (improper tierod geometry). Bumpsteer causes a toe-in affect and the tires will fight each other based on which one is making better contact with the road that instant. If car is not lowered then its alignment toe setting. Performance tires will enhance either of these because of better road grip and less forgiving sidewall on tire.
Old May 25, 2002 | 11:27 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Car isn't lowered. I guess I'll try the simplist thing first and get an alignment.
Old May 28, 2002 | 09:56 AM
Beefy89's Avatar
My 89 GTA did the same thing.Last month I did my suspension(springs,shocks,struts and ball joints)and it's not nearly as bad.
colton_carlson
Mar 8, 2019 12:21 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
