Replacement calipers
Old May 23, 2002 | 12:41 PM
Sergeant's Avatar
I changed the front rotors to cross drilled "Power Stops". Does anyone make an aftermarket BOLT ON caliper? I don't want to go with an entire kit.
Old May 28, 2002 | 03:57 PM
Sergeant's Avatar
"Bueller,...Bueller?"
Old May 28, 2002 | 04:52 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I take it that you're wanting a dual piston type caliper that matches the factory single piston caliper? To my knowledge there's no such "bolt-on" available.
Even if there was, I doubt it would make much of an improvement. You really need to upgrade to larger rotors to make a significant increase in braking.
Old May 29, 2002 | 01:26 PM
johndo1707's Avatar
autozone by me carries oem replacement calipers for only $10 each before core charge, i couldnt believe it!
Old May 29, 2002 | 03:14 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
No you can't get an aftermarket "bolt-on" caliper. The 2 main upgragdes are the 1LE and the BAER systems... I think Brembo has one as well.
Old May 29, 2002 | 03:25 PM
johndo1707's Avatar
i know for sure that tpis.com sells brake upgrade kits and calipers but they may also be brembo. check them out
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
