Will lowering spindles work with aftermarket brakes?
Old May 22, 2002 | 11:17 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Hey Everyone,
Once again thanks for your help.:hail: :hail: :hail:
I have been thining about getting lowering spindles but later I would like to get a nice pair of aftermarket brakes. I have been how you have to cut up the spindle to get them to bolt up to where the dust shield is. Is the shield in a corrected space for the lowered spindles?
Will after market brakes work?
Thanks you for your help:hail: :hail: :hail:
Old May 23, 2002 | 12:53 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'm pretty sure Baer makes a kit that will work with Bell Tech dropped spindles. Other than that, I dunno. That cutting you're talking about is only required when installing 1LE brakes on "modified" stock spindles.
Ed
Old May 23, 2002 | 01:15 AM
Trux's Avatar
Transmission: t-56
Umm...
I thought most upgradeed aftermarket brakes needed the spindles cut to have them fit.
If bear's brakes should fit I think most of them would though.
Thanks for the input:hail: :hail: :hail:
Old May 23, 2002 | 05:37 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I believe this has been discussed on the 1LE "sticky post" w/some pictures.
Old May 23, 2002 | 07:19 AM
Trux's Avatar
Transmission: t-56
ok
I will look for that, thanks:hail: :hail: :hail:
Old May 23, 2002 | 06:24 PM
ebmiller88's Avatar
Yeah, you really need to read that first. That'll save us a whole lot of typing.
Hell, EVERYONE should read that post!!!
TWICE!!!
Old May 24, 2002 | 09:28 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I adapted a set of drop spindles to the BAER track kit. In a nut shell it's the exact same thing as modifying the spindle for the 1LE brakes. Dust sheild? whats that? the BAER setup doesn't have one.
Old May 24, 2002 | 05:12 PM
Trux's Avatar
Transmission: t-56
to do upgrade to the spindles you use the dust shield bolt holes to bot the caliper bracket to the spindle.
Old May 26, 2002 | 03:44 PM
Omega's Avatar
Engine: LS1 / LS3
The dust sheild bolts holes are no longer used.
Old May 26, 2002 | 05:50 PM
Trux's Avatar
Transmission: t-56
Umm..
Do you have to drill your own holes?
everyone I know who has upgraded needed to up the holes to bolt the bracket up for the caliper.
What bolt holes do they use?
Old May 30, 2002 | 12:59 AM
Omega's Avatar
Engine: LS1 / LS3
Yes I drilled my own holes. The bolts I used were 12mmX1.75 Make sure you drill and tap the new holes as straight as you can get them (I don't suggest using a hand drill)
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
