HELP!! 1979 GMC Pickup Brake Problems
Old May 28, 2002 | 05:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Sorry it's not a 3rd Gen, but my brother needs help. He's put on new calipers, new master cylinder, new brake lines. Before the left front would lock up, the caliper on the rotor. So that's when he's replaced all the parts. Now it's still doing it. There's smoke coming out of it. It was fine for a couple miles, and now it has come back. Please help.
Could it be the proportioning valve, though I was told that only affects the front and back, not one side, again this only happens to the left side.
Old May 28, 2002 | 05:57 PM
ede's Avatar
ede
check the fluid preasure on the other side, there may be a restriction there making him use more force on the brake pedal and causing the one side to lock
Old May 28, 2002 | 11:05 PM
Eightyninef's Avatar
you need NEW brake hoses. nothing else is wrong. just the lousy $10 hose. don't feel too bad about the new calipers and whatever else
Old May 28, 2002 | 11:21 PM
Car: 99 Formula
Axle/Gears: 342
Forgot to mention, he got new hoses too. And there's no trash in the lines as the fluid comes out.
Old May 28, 2002 | 11:32 PM
new hoses too ???????
hmmmmmm
maybe the prop valve?? some valves did do the angle thing. not all were front back split. at least that;s what I've heard. I'm not too sure as it wouldn't make sense.......
Old Jun 3, 2002 | 10:00 AM
urbman's Avatar
1. Check the runout of the rotor
2. Alignment of the caliper relative to the rotor
(centering from the leading edge of the pad to the trailing edge)
You are looking for a bent spindle ear or some such...
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
