Power booster Dead?
Old Jun 1, 2002 | 07:45 PM
Absalom's Avatar
Car: 83 Camaro Z28
Power booster Dead?
I have an 83 z28 with four wheel disc. The front two calipars have just been replaced. The rear probably needs some help but has 1LE brakes. Aside from all this, the brake pedal is about as hard as a brick to press and even if you stomp on it it will take a lot longer than it should to stop the car. After working on the front brakes the car stops a little better at higher speeds but at lower speeds I almost have to reach for the E-brake to get the thing to stop. Is my power booster dead or how would I check if it is. Otherwise, what else may be the cause of my crappy braking?
Old Jun 2, 2002 | 03:51 AM
sIcK pUpPy's Avatar
Check all your vacuum line running from your manifold to your PB Booster if you haven't already done so.
JD
fbirdroller
Sep 2, 2015 10:27 PM
sailtexas186548
Aug 24, 2015 10:11 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Bradsaundry
Aug 12, 2015 12:34 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
