car bounces
car bounces
hi, im new to the board and i have a problem. i have a 92 rs 305tbi and when im cruising doing bout 40-75 and i step on the brakes, my whole front end shakes and my wheel bounces like mad. does anyone have any ideas on what would cause this?
your problem is a cracked framerail behind the steering box. I had the same prob. My car would hop like mad when i braked. It was so bad a buddy of mine stopped his car in the middle of trafffic and started running after me cause he thought my wheel fell off :P
The fix? remove the steering box bolts slide it over and weld the cracks. Maybe add a gusset on the bottom for the whole rail. BIG THING.......add a wonderbar to help distribute the load evenly throughout the whole frontend. I haven't had a problem since. No more hopping lowrider.
Good luck
Good luck
Linson
Aug 21, 2015 02:12 PM
I had the same problem with my 88 iroc convertable. I turned the rotors installed new brake pads and packed the wheel bearings and the problem went away.
