posi/disc rear conversion questions!
Old Jun 30, 2002 | 07:59 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
i just scored a posi rear from an IROC it has the rear disc setup on it, i swiped all the E-Brake lines and the pressure lines as well... i am wondering if i need to make any adjustments will the e-brake attatchment, or if i need an adapter for the pressure lines????
Old Jul 1, 2002 | 05:24 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
What year IROC did the rear come from?
That will help me answer some of your questions.
Thanx,ANDYZ28
Old Jul 1, 2002 | 03:14 PM
stevver84Z's Avatar
its interesting actually because the vin says its an 84 v6 car, the VIN was swapped out for some unknown reason... im guessing 86-87, what difference(s) does it make?
Old Jul 1, 2002 | 06:49 PM
ANDYZ28's Avatar
Car: 1982 Z-28
So it is from a pre '89 car. That means that the rear you obtained is/was equipped with the Delco-Moraine cast iron calipers.
From what I have seen posted during the last two years (don't flame me) those calipers are not that desireable.
The '90-'92 rear caliper (PBR) setup on these rears is much more desireable.
I could be wrong, but that is the way it seems to me.
I recieve a great many emails from people wanting to know whrn my drum-to-disc (or early disc-to-late) conversion kit will be ready.
So I am simply going with the flow.
Thanx,ANDYZ28
Old Jul 1, 2002 | 09:57 PM
stevver84Z's Avatar
anybody else know anything about this???? i feel as if ANDYZ28 is just trying to sell me something
Old Jul 1, 2002 | 11:12 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
The disk brakes made pre '89 aren't as good as the ones after, though I doubt they are any worse than the drum brakes so I wouldn't worry about it. I will be performing a similar procedure If I can get my hands on a disk rear.
Old Jul 2, 2002 | 01:51 PM
stevver84Z's Avatar
i am not trying to be rude, and i do appreciate your advice on the quality of my rear, but that was not the nature of my question, i need to know if i need to make any adjustments to fit the rear in, as far as the e-brake and the brake lines go, thank you!!
Old Jul 2, 2002 | 06:19 PM
ANDYZ28's Avatar
Car: 1982 Z-28
No adjustments required. Everything should fit just fine.
Thanx,ANDYZ28
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
