Rear disk
Old Jul 4, 2002 | 09:20 PM
Rage13's Avatar
Car: 89 Firebird
Rear disk
Whats so much better about having disk in the rear and not drums? I've heard from lots of people that the disk are better, so is it true?
Old Jul 5, 2002 | 12:54 AM
urbman's Avatar
errr ...
not really, but...
Lets say your car is like mine was, 13yrs old 120k salty miles
2.73 open rear cheezy cables, cheezy brake lines
Now what are you going todo...
After all the silliness with sorting out a gear swap,
axles bearings posi etc... well might as well do the brakes
and then discs seem like a logical choice...
I started with a fourth gen housing so it was pretty
much a no brainer (except for some part numbers )
I like the way it looks
and theoretically I should experience slightly less
fade during descents
If your rear end is in good shape and the drum setup
is working (not broke) I wouldn't bother
Old Jul 5, 2002 | 06:02 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
He's right. Unless your doing some serious road racing, drums in the rear are fine.
Old Jul 5, 2002 | 07:59 AM
Rage13's Avatar
Car: 89 Firebird
well my rear drums don't work, at all... so i've been trying to decide weather to go with the drums or disk when i change them. car has 94,000 miles and was not taken care of by the last owner.. i plan on redoing the whole brake system, so should i get the rear disk sence the drums are shot anyway?
Old Jul 6, 2002 | 06:39 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
If you subtact the cost of rebuilding your rear drum brake system, from the cost of converting to rear disc brakes. It makes the rear disc conversion much more attractive.
I am currently converting my 1990 IROCZ to rear disc brakes.
Thanx,ANDYZ28
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
