Is this brake line available anymore from GM?
1984 Z28
Rear Drum Brakes
It is the main rear line that runs to the rear to the forward part of the rear wheel well on the driver's side where it splits off to the seperate left/right brake lines.
I have a hole in the line near the connection and have lost almost all braking in the car because of it introducing huge amounts of air.
I need to get this up and working because this is my backup car and the vette needs me to swap transmissions.
Am I out of luck and have to do a custom jobber?
Thanks!!
1984 Z28
Rear Drum Brakes
Thanks!!
I really doubt if it's still available from GM, although I don't think there was much of a change all the way thru 1992 in the tube itself. It will probably be a little pricey anyway because that's the full length run all the way from the proportioning valve to the rear, at least that's what it looks like.
You might also want to check with
www.inlinetube.com
www.classictube.com
www.sdpc2000.com (Scoggin-Dickey, GM parts specialists)
www.finelinesinc.com
Hope this helps, and good luck!
www.inlinetube.com
www.classictube.com
