3rd gen to 1st gen Brake Swap
Old Jul 13, 2002 | 08:11 AM
jdumas's Avatar
Car: '85 IROC
Engine: 305 tpi
Axle/Gears: BW posi w/3.27gears
Is it possible to swap a 3rd gen brake system into a 1st gen car? I have a V6 3rd gen donor car with a drum rear and would like to swap the entire system into my V8 non power/all drum '68 Firebird. I'd like to know as much as possible about this swap before I start ripping into either car such as: what parts will I need off the 3rd gen? Will I have to fabricate anything additional for the swap? Will it really be worth it when I am done? (Keep in mind that this particular '68 is a far cry from a numbers matching purist car and I have no real budget to speak of). Thanks in advance for any help.
Old Jul 13, 2002 | 09:27 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the thirdgen front discs are too puny to stop the car reasonably. i'd go with a larger rotor from a b-body car caprice, impala or monte. they have 12"-13" rotors. i can't remember the size off hand but, a hell of alot better then a thirdgen's 10.5" front rotor.
the rear drums maybe a worthwhile swap..
Old Jul 13, 2002 | 11:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 3rd gen spindles are completely different from 1st gen ones (strut vs upper & lower ctrl arms)... so basically, you really need a 1st gen donor car with disks for those.
About the only thing that I know for sure will swap over is the pads; the calipers might, i don't know about that, but nothing else will.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
