rear drum to disk conversion
Old Jul 24, 2002 | 10:34 PM
82tiresmoker's Avatar
Car: 82 Trans Am
Engine: 305 4bbl
Transmission: 4 spd
Hi everyone. I am about to start working on my 82 Trans Am project car. So I'm sure you'll see me on here a lot. Anyway, the question I have is: what is the best plan of attack to change my rear drums over to disks? I currently have a 3.27 LSD drum rear. Would it be easier to find a whole rear end that already has the disks? or is there some way to easily retrofit disks on my current rear end? I know I will have to change the master cylinder, but do I also have to change the proportioning valve? TIA
Old Jul 25, 2002 | 01:28 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
it would be easier to get a new rear end. YOu could probalby find one for $200-300 maybe even less if you look hard enough. You will have to change the proportioning valve. I suggest getting the adjustible kind. They only cost about $50 and are easy to put in. It will help alot.
Old Jul 25, 2002 | 11:51 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
4th gen Fbodies with V8s and 6 speeds have 3.42 posi disk rears. they are wider though
Old Jul 25, 2002 | 12:31 PM
Parrydise7's Avatar
Start first with the technical articles section. There is an article on putting LS1 brakes in a third gen. This issue has come up so many times that there is all kinds of information available.
Old Jul 25, 2002 | 08:21 PM
Car: 82 Trans Am
Engine: 305 4bbl
Transmission: 4 spd
Ok, I'll check it out. Thanks
Old Jul 26, 2002 | 06:38 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
AndyZ28 is working on this very thing.
I have seen some pics - and the stuff is great.
All 1LE type rear disc setup that bolts on to drum rear brake cars. very slick. He should be releasing the stuff soon - and it will be a COMPLETE kit. Trust me - this will be worth it.
Old Jul 27, 2002 | 07:35 PM
PonchoTA's Avatar
I got one of the very first kits Andy put together, and it IS definitely worth it!! Every bit!!
My braking is awesome now, and it included everything I needed!
Highly recommended!! I posted on the Review Board right after I put them on, check it out!
https://www.thirdgen.org/techbb2/sho...&highlight=OMG
Hope this helps!
BTW, I'm putting together an 83 T/A that I can road race/SCCA F-stock or F-Modified (can't decide which right now!) and these brakes should fit the bill nicely!
jaridjohn
Jul 8, 2024 03:49 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
