One coil cut, 245 tires.(87 TA) How bad will it rub?
Old Jul 27, 2002 | 04:15 PM
68camaro's Avatar
This is on an 87 Trans am and I'de like to cut one full coil from the front and rear stock coil springs to lower it some. It has 245/16 tires and everything else is stock suspension wise.
How bad will it rub/scape?
Thanks,
Donnie
Old Jul 27, 2002 | 05:40 PM
Nasty_Bird_'90's Avatar
i just cut a full coil from my fronts and a full coil +2" from the rears. it lowered the car about an inch all the way around and with 255 50 16's on all four corners, it only rubs with the wheel at full lock. even when they do rub, its not bad at all
Old Jul 28, 2002 | 01:50 PM
68camaro's Avatar
Thanks alot bro! When you say that you cut one full coil plus 2 inches, do you mean 2 more inches around the spring? If so, is that just so the car would sit even?
Thanks alot,
Donnie
P.S. Are you running the stock springs?
Old Jul 29, 2002 | 11:19 AM
damn, i posted a reply yesterday. I wonder what happened to it. Oh well, here we go again . The reason i cut more off of the rear is because there is no weight on the back end of the car so to lower it the same as the front, you have to remove more material from the spring. I cut one full coil, then i cut an additional 2" or so off of the next coil. I would have liked to make only one cut, but i was using a biiiig grinder and i couldn't get the wheel in there so i just made 2 cuts. Yes i do have the stock springs. If anything is unclear, let me know and i will try to clarify it for you. later man.
Old Jul 30, 2002 | 09:01 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
is the ride much stiffer after you cut the springs?
Old Jul 30, 2002 | 10:40 AM
not noticeably. I noticed a little better handling because of the lower center of gravity. I just did it as a temporary thing until i get some Eibach springs. People say you can do some pretty bad things to the suspension by cutting springs.
Old Jul 30, 2002 | 04:20 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Well I have 245/50/16's on my car. And I have a 3" drop all around and mines doesnt rub any. So one coil being cut off shouldnt' do anything.
Old Jul 30, 2002 | 06:16 PM
68camaro's Avatar
REVLIMIT- Got any pics of your ride? The lowest I've seen so far is the cars with the sportlines...I just think that lower would look even more badass!
Later,
Donnie
Old Aug 1, 2002 | 01:44 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
My advice is go slow on those front springs after you whack that first coil out of there. I did it on one of my old 82' firebirds and ended up with a front suspension just sitting on the bump stops. I went 1/2 coil, reassemble, not enuff. 1/2 more, still not nuff. Screw it I thought and whacked 1 more coil, almost there. 1/4 coil, sitting on the on bump stops. It turns out when you reassemble it,. you've got to get the suspension to settle. My car was a v6 with Iroc springs all around. Heres a pic of my GTA with Bell Tech spindles (2" drop) up front and 1.25 coils off the rear springs. I think it needs about .5 - 1" more drop in the rear, but I've got to fix the fuel pump first.
Attached Thumbnails One coil cut, 245 tires.(87 TA) How bad will it rub?-ta_rh_lower2.jpg
Vintageracer
Jan 10, 2020 05:33 PM
Winchester1094
Aug 18, 2015 10:23 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
TA8487
Aug 11, 2015 09:02 PM
