Wonderbars, are they worth it?
Old Aug 1, 2002 | 06:22 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Guys, I hear all this about these "wonderbars". First of all what are they (I dont really know so thought I would ask) and do they make much of a difference to steering/suspension.
Thanks,
Old Aug 1, 2002 | 06:26 PM
Jza's Avatar
Jza
Not a huge difference, but for between $15 and $35 depending on where you pick one up at, it's a good dollar-for-dollar mod.
It's basically a bar that sandwiches between the swaybar bushings and the front subframe and ties them together.
Old Aug 1, 2002 | 06:46 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Wonderbars, are they worth it?
Thanks,
I e-mailed you info about the version I am selling that will explain its function. Also included my Price List. Sorry about the file size being so large. E-mail me if you have any other questions regarding a Steering Brace (aka Wonder Bar).
Lon
Old Aug 1, 2002 | 07:12 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'm selling one on ebay right now, POR-15 coated and all. Search for ebmiller88.
Sorry Lon...
I noticed a difference right away when I put one on my '91 RS.
Ed
Old Aug 1, 2002 | 07:44 PM
lonsal's Avatar
Not a problem Ed. I've shipped 7 this week so far. Less than 12 left in stock. Lon
Old Aug 1, 2002 | 08:51 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Definately well worth it, especially if you have t-tops. You will most certainly notice your front end being tighter.
Old Aug 2, 2002 | 12:07 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Hey lonsal could you throw that list my way. I am always looking for stuff to put on my car.
Old Aug 2, 2002 | 12:15 AM
AFrikinGoodTime's Avatar
A wonderbar will do for your car what a wonderbra will do for your girlfriend. They both stiffen your front end. (dong..)
Old Aug 2, 2002 | 12:59 AM
lonsal's Avatar
I see you believe in recycling too.
Originally posted by DAVECS1 Hey lonsal could you throw that list my way. I am always looking for stuff to put on my car.
Sure, Lon.
Old Aug 2, 2002 | 06:40 PM
Car: 91 RS
Engine: 350 TBI
LMAO
Old Aug 20, 2002 | 10:06 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Will this help my frame from twisting when I turn the wheel hard left to lock? It seems the power steering twists my frame when the car is on jack stands. What the hell????
Old Aug 21, 2002 | 01:57 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Some 3rd gens. have experienced stress cracks in the sub-frame at the steering box mounting point and the wonderbar helps prevent this. It also ties the front sub-frame rails together and helps stiffen up the front end. It's a good inexpensive mod.
Old Aug 21, 2002 | 07:18 AM
lonsal's Avatar
Here is a picture of TDS 105021 Steering Brace for 1983-92 F-bodies, $40. E-mail me at: topdownsolutions@yahoo.com to order it.
Lon
Old Aug 21, 2002 | 06:01 PM
Looks pretty basic to me. Pretty cheap to make I think.
Old Aug 22, 2002 | 10:51 PM
fakezcar's Avatar
thanxs a bunch guys.....I ha no idea what i got.....i've got one sitting in my shed and didn't even know it....i guess i got some more stuff to add to the front end.....sweet....
chris.
Old Aug 26, 2002 | 11:07 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
lon is the wonderbar that you make the same as the OEM?or is it a heavier gage steel?
Old Aug 26, 2002 | 03:52 PM
lonsal's Avatar
Comparable materials were used. 10 gage HRS for the mount pads and .75" OD 11 ga HREW tubing. Mine has a longer weld length. Also the GM version has the formed lip turned up, which can trap more dirt and debris. I designed mine that the formed lip is pointed down. GM Version, is painted. Mine is powder-coated which is a more durable finish. Only 3 left in stock as of today.
Lon
Old Aug 27, 2002 | 03:48 PM
CheezX's Avatar
I made one. Probably overkill though. 3/16" thick brackets and 1" x 0.100" thick tube. Made one for another guy too.
Old Aug 28, 2002 | 12:17 AM
AFrikanGoodTime's Avatar
Yours looks close to Global west's design. Good job.
Here's the way I see it when the question is asked if they are worth it-- GM would not have gone through the trouble of putting one on the Iroc's stock if they didn't feel it was important. The fact is that they did add it for a reason--- The frames will crack under heavier cornering loads via wider tires on the Iroc's sport package. Anyone running their car hard in corners should definately purchase one.
Old Aug 28, 2002 | 01:22 AM
CheezX's Avatar
Good enough to sell?
Old Aug 30, 2002 | 03:18 PM
Gta-Paladin's Avatar
sure cheezex i'll buy one
Old Aug 30, 2002 | 10:04 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
I think I've got one of those on my car but I didn't install it. Do they go between the radiator and the crossmember? I know there's 1 like 2 inches in front of the crossmember but that's for the steering, but then there's the one probably about 5-6 inches away from the crossmember, and 1-2 inches away from the bottom of the radiator. Is that it?
Old Aug 30, 2002 | 11:57 PM
CheezX's Avatar
Really?
The bar mounts between the swaybar brackets and the frame. Its the one closest to the radiator in front of the swaybar.
Old Aug 31, 2002 | 12:35 AM
sure why not as long as i dont get so bored i fabricate one
Im sure others would too
Old Aug 31, 2002 | 04:08 AM
CheezX's Avatar
ok you can order them online at www.maniacmotor.com.
ignore the celica stuff. I'm in Vancouver so shipping should be cheap
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
