restoring car, starting with suspension
Old Aug 8, 2002 | 06:29 PM
primer84z's Avatar
ive decided to bring my car back to show quality and most of the suspension components are the ones that came off the factory line. what all should i refresh? heres my list so far:
shocks/struts
brakes/drums
a bushing kit for front and rear
after that i go blank. what else can yall think of? i was condsidering springs but those are pricey arent they? and difficult to install. thanks for the help.
Old Aug 8, 2002 | 06:45 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Springs really aren't that expensive. You should look into it. If you are doing suspension, go ahead and get a set of subframe connectors. They are well worth the money and should be at the top of the to-do list.
Old Aug 8, 2002 | 10:24 PM
primer84z's Avatar
would SFC's help prevent frame twisting and bending in a wreck? thats about the only way i could justify putting them on becuase my parents already think its a race car.
Old Aug 9, 2002 | 01:14 AM
Garett92Z's Avatar
yep. They stiffen up the car. You will get less creaks, rattles, shakes etc. the car will feel more solid/well-built. It also prevents unibody flex which can cause cracking in the paint/body among other things after years of hard work. They may even take a tenth off your 1/4 time if your unibody was weak and flexing around a lot etc.
They are a great thing to get.... get the weld-ins.
Old Aug 9, 2002 | 08:48 AM
primer84z's Avatar
where can i get them? how much do they cost to weld in? i dont have welding equipment so thats out of the question?
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IroczFan
Oct 6, 2015 10:13 AM
Wade787b
Sep 29, 2015 01:15 PM
