proportioning valve "mod" question
Old Aug 9, 2002 | 12:36 AM
AFrikinGoodTime's Avatar
proportioning valve "mod" Brake Warning Light Question
Has any one that has remove the front plug and plunger unit to boost rear brake pressure experience whether the brake warning light stays on, or off, or even functions properly at all?
This subject was mentioned in the previous valve mod post, but never answered to my knowledge. I'd like to know this info before is mess with it at all-from a safety standpoint.
Old Aug 10, 2002 | 04:46 PM
AFricanGoodTime's Avatar
Re: proportioning valve "mod" Brake Warning Light Question
Bringing it back into sight, still loking for an answer from anyone that has performed this? Thank you
Old Aug 10, 2002 | 07:37 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I did it to mine, no light, my only problem was that the stock valve was junk. I ended up putting on an adjustable on mine. My buddy's 89 GTA we did the same thing to his, seems to work better and the brake light doesn't come on.
Old Aug 10, 2002 | 08:22 PM
Thank you Iroc212 for your help.
Old Aug 13, 2002 | 01:08 PM
Bob S's Avatar
Did the mod today and it made a vast improvement in braking performance. No brake light problems either. After chasing so many different things (master cyl,booster test,caliper rebuilds,bleed ,bleed, and bleed) I can't belive this helps so much. This would make a great tech article.
Old Aug 13, 2002 | 08:55 PM
AFrikanGoodTime's Avatar
I haven't gotten to mine yet, I'm waiting for a week day off next week so i can run over to a local industial hardware place(open only on weekdays) and match up a plug fitting in place of the original plug. I don't like the idea of altering the existing plug nut. When I find out wht size and type of nut of plug unit I use, I will post it for others, I'll have to match up the existing one's threads to the new plug to see what size we need.
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
